Pros & Cons Of Dual Boot or Partition
36
Location
Canada
This is just a simple thread that i created to get some info on the PROS & CONS on DUALBOOTING & PARTITIONS. Please Post Away :)
    Hp Pavillion Media Center m8532
    Core 2 Quad Q6700 (K) 2.66 GHz - 1066 MHz front side bus
    Manufacturer: Asus, Motherboard Name: IPIBL-LB,P/Compaq moth
    4 GB - 240 pin, DDR2 SDRAM
    GeForce 9500 GS
    Integrated High Definition audio -Realtek ALC 888S chipset
    42'' V/MAX + 20'' Samsung
    1080p
    750 GB SATA 3G (3.0 Gb/sec)
    7200 rpm
    350W
    54 mbps
    ALWAYS HAVE PROBLEMS! :'(
591
Location
United States
Cons: Having many partitions can hinder hard drive lifespan, (im not sure if thats true, can someone confirm?).
Pros: Having multiple os'es can make troubleshooting easier, and trying something that doesnt work with on OS you can try it on the other.
Con: Your bootmanager can get screwed up if u multiboot wrong.
Con: General multiboot sequence is as follows: older OSes first then later os'es, and linux you install last, this can lead to some trouble as people with vista, trying to dual boot with windows xp, can lead to some problems, but not all the time, you get less errors if u follow the sequence given.
Pros: Fun to learn
Con: Things can go wrong
Con: you have to defragment ur hdd before partitioning, to prevent data loss
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm
    1 linux ubuntu partition
    1 vista partition
    1recovery partition
    1 windows 7 partition
    1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
MilesAhead
Eclectician
2,442
Much of what you learn about how computers function involves the boot sequence. You should learn quite a bit. The thing that saved me more often than not is having access to the net to find the fix. If the only net access you have is the machine you just hosed, it's tougher to bail yourself out.
I've played around with multiboot a few times over the years, but the real insane experts hang over at BootLand
Just about anything you could possibly want to know about a computer and booting, you can find at least the starting point on that site.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
36
Location
Canada
thanks guys.
That bootland site is amazing they really know what their talking about!
    GeForce 9500 GS
    1080p
    7200 rpm
    350W
    54 mbps
patio
Vista Pro
403
False.
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA
    200G Seagate SATA
    100G WD Caviar SATA
    80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2
    Dos 6.2;Win2K;XP; &
    Vista Ultimate 64Bit.
garysgold
930
Location
Maine, USA
I like having a second OS installed so if the first one tanks or if I need to backup AppData or other files normally in use, for a reinstall, I can do it unhampered from the second OS. When we finally get some Win 8 bits to play with, it will go in that space. I generally try new software in a Virtual Machine.
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    2-WD5000AAKS-500 GB
    WD 5000AAV-500 GB external
    MX Revolution
    Microsoft Comfort Curve
    Wacom Intuos 2 Graphics Tablet
    Experience Index=5.5
Bare Foot Kid
R.I.P. August 13th 2014
2,616
Location
The Lowcountry
Thanks MA, I may have a look at that site. :shock:
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
MilesAhead
Eclectician
2,442
#8
You're welcome. My favorite thing I found there so far.. using a USB key just like a Linux boot diskette, only you get the Windows boot manager(like if your MBR got hosed the USB key would load the Windows OS off your HD like Linux.) If you are multi-booting say W7 and XP or whatever, when you boot from the USB key you get the same boot menu. A pretty cute USB trick.
Just like the Linux boot diskette, it's tied to the particular machine and HD you made it from. Still, might be good thing to stick on a $5 bought on sale USB key just for the hell of it.
(btw thanks for the rep)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Bare Foot Kid
2,616
Location
The Lowcountry
#9
Thanks for the info! ;)
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
591
Location
United States
#10
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm
    1 vista partition
    1recovery partition
    normal black case
    fans
    dsl
    2.3 ghz amd
patio
Vista Pro
403
#11
:D
    Intel Q6600
    ASUS P5K MBoard.
    500G Seagate SATA
    200G Seagate SATA
    100G WD Caviar SATA
    80G WD Caviar IDE
    OCZ Elite 800W PSU
    Dos 6.2;Win2K;XP; &
