Protected Mode Off?
Fred44
Under Security tab, "Enable Protected Mode" is ticked, but there is no message at the bottom of the screen indicating if it is on or off. Also the option to increase or derease font size is gone. The whole bar at the bottom has disappeared, I've recently had to switch anti virus software and maybe something happened during the process. UAC is on.
Fred
    HPs3700y Slimline
    AMD Athlon64 X2 (B) 50000+ 2.6 GHz (65W)
    Asus M2N61-AR
    3 GB
    NVDIA GeForce 6150SE nForce 430 (Integrated on motherboard)
    High Definition 6-channel audio ALC 888S chipset
    SAMSUNG SYNCMASTER 914V FLAT PANEL LCD
    1280 X 1024
    320GB SATA 3G (3.0 Gb/sec)
    160W
    HP
    Logitech Marble Mouse
    Broadband Cable Connection (256 Kpbs?)
    Not sure what case or cooling means. Could not find in any documentation. The keyboard is the standard that comes with the HP Slimline.
Hello Fred,
Sounds like you may have accidentally unchecked the Status bar in Internet Explorer. Right click on a empty space on the top toolbar by the tabs, and click on Status Bar to check it.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
