Proxy not working
M
mattadata
I need to connect through a proxy at work. It is HTTP with authentication. It
worked fine in Foldershare. I tried all settings, including the one that
says, "user browser settings". IE and Firefox both work fine when I have them
use my proxy info.
How do I get this to work through my proxy like Foldershare did?
D
Doug Robbins - Word MVP
To stop you bashing your head against the wall, in other places MS have
advised that at the moment, Live Sync does not support an authenticated
proxy. They say they are working on the issue. You'd have thunk that they
would have got that working before chopping us off.
Hope this helps.
Please reply to the newsgroup unless you wish to avail yourself of my
services on a paid consulting basis.
"mattadata" <[email protected]> wrote in message
news:[email protected]
>It
> them
> use my proxy info.
N
Nimrod
Hi
I too have been unable to connect at work since the moment Live Sync
started. I have had the technical chaps out and they fiddled with the proxy
– no problem there – they suspected a port was closed, but that too ended in
a dead end.
So, my two questions to Windows Live Sync Team (e.g. Jeremy) are;
“Do I have to wait for MS to ‘fix’ Windows Live Sync before I can connect
through my work’s proxy? Is there nothing that I or the technicians can do
to get me working again?â€
Kind regards
Mike
> use my proxy info.
