quick boot?
D
Debbie
I am sitting for 4 or 5 minutes while my system boots. There is a black
screen, then the window's progress bar (RAM check?) and then the desktop
shows with no icons. Then the screen blinks TWICE to black and finally I see
my icons. But the computer is not ready to use yet.
I used to go into the msconfig and tweak the startup stuff but I cannot do
that in Vista. I am TOO afraid I am going to mess it all up.
I read an article on Quick boot, but cannot find it in the setup (F2) or the
boot device selection (F12) on this computer. Any ideas?
I have a Toshiba A135-S4487 Laptop that was bought new in Feb 07 with Vista
Home Premium. Love it but takes SO much time to start working.
Thanks!!
Debbie
Debbie
Brink
Staff member
mvp
Thanks!!
Debbie
Debbie
Hi Debbie,
This tutorial will show you how to do a quick restart by explorer.exe or logoff and logon.
http://www.vistax64.com/tutorials/78012-restart-explorer.html
D
Debbie
Debbie
> > desktop
> > I see
> > do
> > or the
> > Vista
> > Thanks!!
> > Debbie
> > Debbie
> Hi Debbie,
> Shawn
> brink
> *There are no dumb questions, just the people that do not ask them.*
> WWW.VISTAX64.COM (\"HTTP://WWW.VISTAX64.COM\")
> *Please post feedback to help others.*
HI Shawn -
While this tutorial taught me something new and useful, and I thank you for
that - it did not really answer my question.
I am looking for a list of changes, or a change, in the BOOT process - a
cold boot if you will - so that the computer ready to use quicker! I have
looked in the F2 and F12 bios options, and cannot find what I was told is a
"Quick boot" feature. This supposedly eliminates the RAM check (remember the
old DOS RAM check? You could see it on the screen as it went through all the
RAM?) and other slow boot processes.
Thanks again for your response!
Debbie
C
Carl G
What you are refering to is called silent boot in my bios under boot
options on an intel board desktop.
Carl G
"Debbie" <Debbie@xxxxxx> wrote in message
news:45739CCA-1A72-42DB-A95F-FA17908A1FB9@xxxxxx
> Debbie
>> > desktop
>> > I see
>> > do
>> > or the
>> > Vista
>> > Thanks!!
>> > Debbie
>> > Debbie
>> Hi Debbie,
>> Shawn
>> brink
> HI Shawn -
> for
> a
> the
> the
> Debbie
D
Debbie
Thanks "Carl G" I will look into it.
Debbie
> Carl G
> > Debbie
> >> > desktop
> >> > I see
> >> > do
> >> > or the
> >> > Vista
> >> > Thanks!!
> >> > Debbie
> >> > Debbie
> >> Hi Debbie,
> >> Shawn
> >> brink
> > HI Shawn -
> > for
> > a
> > the
> > the
> > Debbie
D
Debbie
Carl -
i have a "quiet boot" in the boot area of the bios. It is enabled. I do not
have a silent boot or a quick boot anywhere - F2 of F12 - to get into the
bios.
Any other ideas?
Thanks again!
Debbie
Debbie
> Carl G
> > Debbie
> >> > desktop
> >> > I see
> >> > do
> >> > or the
> >> > Vista
> >> > Thanks!!
> >> > Debbie
> >> > Debbie
> >> Hi Debbie,
> >> Shawn
> >> brink
> > HI Shawn -
> > for
> > a
> > the
> > the
> > Debbie
Brink
Staff member
mvp
Carl -
bios.
Any other ideas?
Thanks again!
Debbie
Debbie
Debbie, I checked by BIOS for those older options to and did not see them either.
All I can offer is another tutorial that will save 30 seconds during boot up.
http://www.vistax64.com/tutorials/70563-boot-up.html
Hope it helps you some.
D
Debbie
#8
Thanks, brink! I did the 30 to 5 second to operating system change already. I
am looking for insight, now, into unchecking things in the msconfig startup.
I am just nervous and don't want to uncheck something that i really need but
don't know it!
Thanks -
Debbie
"brink" wrote:
> Debbie;529725 Wrote:
> > Carl -
> > not
> > the
> > bios.
> > Any other ideas?
> > Thanks again!
> > Debbie
> > Debbie
> them either.
> boot up.
> Shawn
> brink
Brink
Staff member
mvp
#9
don't know it!
Thanks -
Debbie
> them either.
> boot up.
> Boot Up
> Shawn
Your welcom Debbie,
For "Startup", see: (The guides will really help in deciding)
http://www.vistax64.com/tutorials/79612-startup-programs-enable-disable.html
For "Services", see:
http://www.vistax64.com/tutorials/59910-services.html
You might also look at these other tips to help improve the performance of Vista.
http://www.vistax64.com/tutorials/81176-speed-up-performance-vista.html
