Quick help please :(
ShadowTwin
Hi there
my problem is that i have the windows color before but it's not there any more, i don't know why?
i download Aero and i find it when i right click and i press Turn Aero On , but nothing happens and i also can not find it when i click in the Color Scheme :cry:
so pleaseeee help meee:cry: as soon as possible
Thank you
garysgold
Hi Shadow Twin,
Without knowing your system specs (processor, ram, video, vista basic-premium, etc.) it is impossible to give you an answer. Does your computer have enough power to run Aero?
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    2-WD5000AAKS-500 GB
    WD 5000AAV-500 GB external
    MX Revolution
    Microsoft Comfort Curve
    Wacom Intuos 2 Graphics Tablet
    Experience Index=5.5
ShadowTwin
hey thanx for your replay :)
i have Vista Home Premium
Ram : 2.00 GB
recovery (D: ) total size: 9.99 GB
recovery free spec: 5.74 GB
OS Total size : 220 GB
OS (C: ) free spec: 161 GB
by the way, i don't know so much about computer system -_-'' ..so if any thing missing tell me please..
and Thank You again
garysgold
Hi ShadowTwin,
You didn't list your graphics card (harddrive space isn't needed here. You can find that by going to control panel (classic view) and clicking on device manager. Click the plus sign next to 'display adapters'.
Since you say that you right click and select 'turn aero on' I am guessing you have 'turn aero on/off' on your right click menu. Aero comes with Home premium so no need to download it. If you are speaking of the downloads from the tutorial section of the x64 forums, that is just to add the on/off menu items.
Try this. Right click on the desktop. Select personalize. Click on
Windows color & appearance. If Aero is not enabled, you will get a box to select a color scheme. Select Aero as the color scheme. OK. If you still don't have transparency, you will have to go through the above steps again except now you will get a window that has a checkbox to turn transparency on/off and to select colors. Check that box and you should be good to go. Now the Aero on/off menu items should work properly.
Hope this helps you.
Gary
    Creative SB X-Fi
    HP w2207 + HPvs15
    2-WD5000AAKS-500 GB
    MX Revolution
