Quick Start Toolbar size - Order of Icons
F
Fergarbu
Hi all. I would like to know how to fix the size of the quick start toolbar,
as I have to enlarge it every time I start windows. I would like it to have a
fixed size if possible. Also, icons are organised by alphabetical order and I
would like to change that, but every time I start up windows, they go back to
alphabetical order. Please advise. Thanks.
N
Norbert
The easiest way I've found of making your quicklaunch settings "really
permanent" is by using Free Launch Bar: http://www.freelaunchbar.com/. It
was made for XP, but works fine here with Vista too.
Regards,
"Fergarbu" <Fergarbu@discussions.microsoft.com> wrote in message
news:F56AED18-9484-494E-BFD2-8589D22A9199@microsoft.com...
> toolbar,
> have a
> and I
> to
K
Keith Miller MVP
The toolbar layout settings are unusual in that they are read at login, held
& modified in memory throughout a session, & only written at logoff.
So the first thing to try is logging on, configuring Quick Launch, then
logging off & back on. If they're not saved, check your event logs to see
if any errors are being generated during logoff.
Good Luck,
Keith
Microsoft MVP [Windows XP Shell/User]
> toolbar,
> have a
> and I
> to
F
Fergarbu
Thanks Keith. I am not fluent in admin tools, and can not understand all the
messages in the event viewer... I will keep on trying. Thanks again.
> Good Luck,
> Keith
> > toolbar,
> > have a
> > and I
> > to
