quicktime file wont delete
R
rachel3cookie
hi can someone help please i downloaded a quicktime file it is a movie
trailer of 2000 years bc i tryed to delete it but have had no luck
geting rid of it no matter what i do i canot delete it has anyone had
the same problem? can anyone advise me how to get rid of it i would be
very thankful
Are you receiving a message when you try to delete it?
<rachel3cookie@xxxxxx> wrote in message
news:7111d85e-0567-48c2-b66a-d9e8ce3fea4d@xxxxxx
> very thankful
C
Chris Jones
>> very thankful
Try booting in safe mode and deleting it, if you can't delete it there i
would suspect it's some kind of malware in which case you should google
the file name and see if anything shows up with a way to delete it.
bjg123
5
Nope, I don't think it's malware. I had the same problem and found a solution on another thread. Just uninstall Quicktime (it may prompt you to reboot in order to complete the uninstallation) and then delete the file. Quicktime seems to have all sorts of conflicts with Vista.
