Ram Problem
544
Location
Rhode Island
Hey everyone,
I just bought 2x "1GB PC2 4200 4300 DDR2 533MHZ 240 PIN 1 BG CL 4.0" ram sticks for my dell inspiron 530 and they wont ork. I installed them right and the slots all lined up right so i know they fit. but when i go to start it up, instead of beeping once after about 5 seconds after i hit the power button on, it takes about 2 seconds, the it goes beep beep and nothing comes up on the screen.
I am very good with the software part of computers but the hardware i am litterally dumb as $h!t with.
Can anyone help me?
Thanks,
Ben
    Dell
    Intel(R) Celeron(R) CPU 420 @1.60 GHz
    Dell Inspion 530 Default
    PNY 4GB 240-Pin SDRAM DDR2 800 (PC2 6400) Dual Channel
    ATI Radeon HD 2400 PRO
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Seagate 250G ATA SATA-II
    Dell Inspiron 530
    None
    Logitech EX100 Combo
    100 MB/s
skunksmash
im coming for cake
2,254
Location
norfolk
Hi Ben....;)
im willing to bet its your Dell mobo being picky about the DIMMs.....
either your boards not feeding enough power to run the sticks @ stock speed, or your board cant recognize the DIMMs ''Jedec'' settings...
first you need to confirm the new sticks actually work, you need to find a machine to test them in...
can you run 1 ''new'' stick, in any slot..??
try & update your motherboard BIOS via Dell's website, this may help with newer RAM compatibility.........
(:devil:please use caution:devil:)
unfortunately if it is a voltage issue your pretty much buggered with a locked BIOS, you will need to fit the exact DIMMs Dell recommend for that board...
let us know if you have confirmed the RAM works & you have the latest BIOS.
EDIT: ..... are you using the right banks..?? (1+3) (2+4)
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
544
Location
Rhode Island
Thanks, skunksmash,
I tried only one and it doesnt work. Ill try the update and let you know
Thanks a ton,
Ben
Hi Ben....;)
:)SK
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
544
Location
Rhode Island
Ok, so i just updated my bios and now im gunna shut down, try both at once and just one at a time and ill let u know.
thanks ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
544
Location
Rhode Island
It didnt work. I got the Double Beeps again.
Am i out some Ram or is there anything else i can do.
It would suck because i only have 2x512MB sticks right now
ANything else?
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
skunksmash
im coming for cake
2,254
Location
norfolk
there aint much else i can suggest really..... (its a Dell :()
if your 100% sure the new sticks work..?? your gonna have to find some more RAM, the fact it wont even post tells me your board really don't like those sticks...
your motherboard manual should have a list of compatible sticks, if not their website should...
is there any way you can take those sticks back..??
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
544
Location
Rhode Island
idk i ordered them from EMARTBUY.COM
so
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
544
Location
Rhode Island
#8
Damnet should have checked this first. The memory i ordered was 533MHz.
This is for my computer
Type:
DDR2 SDRAM(667/800-MHz)
Memory connectors:
four
Memory capacities
512 MB, 1 GB or 2 GB
Maximum memory
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
skunksmash
im coming for cake
2,254
Location
norfolk
#9
ring them & just say you made a mistake, you bought pc4200 (533mhz), you need pc5300 (667mhz) or greater ;)
remember... RAM is backwards compatible, 800mhz can run at speeds of 667mhz & 533mhz by default, but 533mhz RAM can NOT run @ 667mhz or greater with no adjustments....
hopefully they will exchange them, you will no doubt have to pay the shipping though..
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
544
Location
Rhode Island
#10
Thanks a ton man. Great advice. Deff rep worthy.
Ill contact them tommorw.
Ill let you know.
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
johngalt
Antidisestablishmentarian
3,912
Location
3rd Rock
#11
Also, let this be a lesson for you - don't rely on what some website says you need in terms of hardware - do the research yourself and know your hardware.
  • Show second system?
    Yes
    Operating System
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
544
Location
Rhode Island
#12
I know John.
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
johngalt
3,912
Location
3rd Rock
#13
That wasn't *just* for you, money - everyone needs to realize that you can't necessarily use rims from a Nissan Altima to fit a Honda Accord - same holds true for computers - RAM that *I* can use may not be suitable for your machine....
    Yes
    Operating System
    The Beast Model V
    2 * 1920 x 1080
    Logitech MX Master
    Dell Inspiron 3521
    Dell
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Dell
544
Location
Rhode Island
#14
I know that john. I did some research but obviously am not very good with the hardware part of computers.
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
