Re: 5308-64: Serious file I/O issue?
  • Thread starter Zack Whittaker \(R2 Mentor\)
  • Start date
Z
OK, I've tried doing this with a Futurama video (I used Movie Maker to make
it into a Pocket PC optimised file) so that made it 63MB which is
thereabouts OK. That works fine.
I tried zipping my entire Counter-Strike directory which amazingly comes to
1.02GB and that also works fine... try submitting this as a bug :o)
Zack Whittaker
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: www.msblog.org
» Vista Knowledge Base: www.vistabase.co.uk
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--- Original message follows ---
"Vista Tester" <[email protected]> wrote in message
news:[email protected]
> I'm finding serious problems (system lock/crash) trying to xfer files from
> a shared folder across a network. So far, it only seems to be a problem
> in the 64-bit version of Vista.
> Try placing a 50MB file in the Public folder on a 64bit system. Make sure
> sharing is turned on. Then, go to another machine and try to copy the
> file through the network. If that works, then try it with a 1G file.
> There are a LOT of variables here, so before I spend much more time trying
> to diagnose, I wanted to find out if others had noticed any issues.
V
Vista Tester
Sorry to hear that :) Sounds like I've got a bit more work ahead of me.
What was the system configuration on the other machine?
"Zack Whittaker (R2 Mentor)" <[email protected]> wrote in message
> make it into a Pocket PC optimised file) so that made it 63MB which is
> to 1.02GB and that also works fine... try submitting this as a bug :o)
> Zack Whittaker
> not of my employer, best friend, Ghandi, my mother or my cat. Glad we
> cleared that up!
>> from a shared folder across a network. So far, it only seems to be a
>> problem in the 64-bit version of Vista.
>> sure sharing is turned on. Then, go to another machine and try to copy
>> the file through the network. If that works, then try it with a 1G file.
>> trying to diagnose, I wanted to find out if others had noticed any
>> issues.
Z
Zack Whittaker
Well, I had two machines:
Machine 1: \\VISTACHROME
256MB RAM, AMD 1900+ 32-bit processor
30GB hard disk space, Glass enabled.
System Performance Rating: 2
Machine 2: \\VISTAPLATINUM
1GB RAM, Dual Core AMD 64
230GB hard disk space, Glass enabled.
System Performance Rating: 4
Transported files from \\VISTACHROME to \\VISTAPLATINUM over the network,
with Windows Server 2003 R2 server in place.
Zack Whittaker
Windows Server 2003 R2 Mentor
that up!
> news:[email protected]TK2MSFTNGP10.phx.gbl...
>> Zack Whittaker
>> cleared that up!
>>> file.
>>> issues.
V
Vista Tester
Zack - I'm not sure that I can. I'm one of them beta-tester wannabies so I
don't have access to the connect site...
> Zack Whittaker
> cleared that up!
>> issues.
Z
Zack Whittaker
Ahh course you can! Download the Beta Client here:
http://go.microsoft.com/fwlink/?LinkId=43655 and when you go to submit,
simply click the button that says "File this report anonymously".
But the question asks... how did you get the copy of 5308 if you're not a
tester? ;o)
Zack Whittaker
that up!
> I don't have access to the connect site...
>> Zack Whittaker
>> cleared that up!
>>> file.
>>> issues.
V
Vista Tester
Gotcha.
I got 5308 through MSDN
"Zack Whittaker" <[email protected]> wrote in message
news:%[email protected]
> tester? ;o)
> Zack Whittaker
> cleared that up!
>>> Zack Whittaker
>>> cleared that up!
>>>> file.
>>>> issues.
Z
Zack Whittaker
Oooh sorry, getting 5308 and 5342 mixed up... if you weren't a techy tester
and got your hands on 5342, I'd be worried! :oP
Zack Whittaker
that up!
> Gotcha.
>> tester? ;o)
>> Zack Whittaker
>> cleared that up!
>>> so I don't have access to the connect site...
>>>> comes to 1.02GB and that also works fine... try submitting this as a
>>>> bug :o)
>>>> Zack Whittaker
>>>> and not of my employer, best friend, Ghandi, my mother or my cat. Glad
>>>> we cleared that up!
>>>>> copy the file through the network. If that works, then try it with a
>>>>> 1G file.
>>>>> issues.
