Re: age of empires 3
B
Bob Bell
I solved this prob by going to majorgeeks.com and downloading the k lite
codec pack and installing it. this has the fraunhofer codec's in it plus a
lot of others. haven't had any probs with any sound or video formats since.
"Night Owl" <[email protected]> wrote in message
news:[email protected]
> my system plays mp3's fine, i had an onboard sound chip, and replaced it
> with a audigy to rule out the old sound chip. still dont like me
> ok this is the exact message
> the fraunhofer iis mpeg layer - 3 codec (13codecx.ax) cannot be found on
> this computer. it is a required component of microsoft directshow, and is
> required for proper sound playback in age of empires 3. please quit out
> and reinstall this codec befor continuing. if you choose to continue, an
> alternative audio codec may be used which may cause problems including
> choppy sound, delayed sound and possible game crashes.
> then i get the option to attempt to run or exit game.
> now i found the following on the eso website. but this does not work also
> The missing file is one that comes standard with windows. It may have been
> deleted by the user, or possibly with the installation of a codec pack.
> Here is what you can do to restore the missing Fraunhofer codec
> (l3codecx.ax):
> 1. Insert your Windows XP disk.
> 2. Go to Start->run
> 3. run: expand e:\i386\l3codecx.ax_ c:\Windows\system32\l3codecx.ax
> 4. run: regsvr32 l3codecx.ax
> Substituting the proper drive letter and system path.
> Alternatively, you can copy the file from another machine (from the
> Windows\system32 directory) and then do step 4.
> what to do?????
>> every time i try to run aoe3 i get a dialouge box saying that the mp3
>> codec is missing..
>> if i select run anyways, it works fine..
>> i have installed an mp3 codec and still get the same dialouge prompt.
>> any ideas on this one??..
>> thanks
N
Nightowl
yeah i downloaded the fraunhofer codec and installed it... still get the
same problem..
just doesnt see it..
"Bob Bell" <wildonemtx[email protected]> wrote in message
>> been deleted by the user, or possibly with the installation of a codec
>> pack. Here is what you can do to restore the missing Fraunhofer codec
>> (l3codecx.ax):
>> 2. Go to Start->run
>> what to do?????
>>> codec is missing..
>>> thanks
