Re: AppHangB1
P
petakin
have you found a resolution to this problem? i am having the same problem
with a clean install of Vista on a new machine.
"Thyren" wrote:
> I had the version 8.1 installed and I didn't know there was a newer version,
> So I just installed the version 8.5, but it does EXACTLY the same thing :-(
> Any other idea?
> "kashmiri" wrote:
> > have you tried to update messenger to the latest version 8.5?
> > k.
T
Thyren
Hi Petakin,
Unfortunately, I still haven't :-(
I requested help from Microsoft official support and after several days of
testings, debugging, deleting of registry keys ... , they kept asking me the
same questions and wanted me to do things I had already done dozens of times,
so I finally gave up, and I use gmail chat instead... with only a couple of
people :-/
I could use webmessenger, but it's really not that good.
If anyone had found a solution for this, I would be thrilled, but it seems
to me that MS can't even figure it out themselves, so it's gonna be tough I
guess...
good luck!
> > Any other idea?
> > > k.
P
petakin
My specific problem was that Messenger could not sign on--and if it managed
to sign on, the connection was broken. i have FOUND a solution! In Windows
firewall, i opened the TCP ports 443 and 1863. this feature also may use TCP
port 80. This information was on http://support.microsoft.com/kb/927847--in
case your problem is different. that page has a list of ports and URLS that
the different messenger features may need.
Hope this helps.
"Thyren" wrote:
> Hi Petakin,
> people :-/
> guess...
> good luck!
> > > Any other idea?
> > > > k.
Colis
2
Click: All programs
Click: accesories
Click: Run
type: Regedt32.exe
Click: HKEY_LOCAL_MACHINE
Click: SOFTWARE
Click: microsoft
Click: DirectPlayNATHelp
Click: DPNHUPnP
to the right you should see a AB icon followed by (Default).
RIGHT Click: (Default)
Click: modify
type under "Value data": 2
Click: OK
And give it ago, it worked for me so I'm sure it'll work for someone else. If it doesn't then you may need a cuddle, in the mean time use: MSN Web Messenger
hope this helps.
