Re: Connot print from Internet Explorer
P
PA Bear [MS MVP]
Forwarded to Vista Print_Fax_Scan newsgroup via crosspost.
~Robear Dyer (PA Bear)
MS MVP-IE, Mail, Security, Windows Desktop Experience - since 2002
AumHa VSOP & Admin http://aumha.net
DTS-L http://dts-l.net/
Happygolf wrote:
> When I go to print from Internet Explorer the following error message
> appears. Cannot find
> file////C:users/Elizab~1/Appdata/local/temp/low/foylu56t.htim (the last
> part changes each time you try to print a page from the web.) Make sure
> the
> path or Internet address is correct.
> Printing anything else works ie e-mails documents etc.
> Trying printing by pressing icon, tool bar and file print nothing works.
> Can anyone help.
> Elizabeth
