re-enable hardware
W
Wingdom
I disabled my built in microphone in my notebook, because I couldn't find how
to mute it. Now I need it, and cant figure out how to re-enable it. I also
still haven't found out how to adjust the input volume of the mic.
M
Mike Hall - MS MVP
If you have no machine specific manual, you may want to ask the manufacturer
how to re-enable the mic..
When you have it back, the mic volume can be found in the Vista Sound
panel..
"Wingdom" <Wingdom@discussions.microsoft.com> wrote in message
news:DAC14DCE-F46B-492D-9E9A-EC37D5CF1E49@microsoft.com...
>how
Mike Hall
MS MVP Windows Shell/User
http://msmvps.com/blogs/mikehall/
W
Wingdom
Wouldn't re-enabling the hardware be the same for any piece of hardware in
vista? In the device manager list, you can disable and enable hardware, but
the mic. isn't showing up there. Theres gotta be somewhere in the OS that
will let me do this
M
Michael
A microphone is not connected directly to the computer, it is connected to
an audio card, that is the device that device manager can see. To controll
the microphone you need to use the app that came with your audio card.
There ought to be a speaker icon in lower right that will allow you to
enable the microphone again. Exact miliage here depends on specific audio
card.
For me:
right click on speaker
select recording device
should show inputs (line input, microphone(s) etc)
you are on your own from there
Michael
news:46AEFA76-18B1-4AF4-A900-403AFDAB2241@microsoft.com...
> but
> will let me do this
W
Wingdom
Yes, that is exactly how i found it to disable it, but now its not in that
list. I wonder if my audio card has any more advanced options. Its the
Reaktek High Definition Audio card. Ill keep looking, but i get the feeling
im still going to need some help.
D
dean-dean
Right-click the Sound icon in the notification area, and choose Recording
Devices. On the Recording tab of Sound, right-click an empty spot of the
window, and put a checkmark next to "Show Disabled Devices" and "Show
Disconnected Devices".
news:46FC6309-83CC-4CD2-825C-D58DD1EADB42@microsoft.com...
> feeling
M
Mike Hall - MS MVP
Control Panel - Sound - Recording (tab)..
> feeling
Mike Hall
W
Wingdom
#8
Thank you very much dean-dean, this is exactly what i needed to do. Thanks to
everyone else for your help, too.
N
ninjaneer
#9
you're the best dean-dean
i had the same problem
> > feeling
C
centerlawn
#10
I just had the same problem - and your advice solved it for me. Thanks.
> "Wingdom" <Wingdom@xxxxxx> wrote in message
> news:46FC6309-83CC-4CD2-825C-D58DD1EADB42@xxxxxx
> > feeling
K
KatieMatey
#11
Nearly a year later and your little quote is still helping, i am now out of
my panic. Thank you!!!
technically challenged
> > feeling
J
jillmuhm
#12
My microphone shows under recording devices but currently shows as
"currently unavailable". How do I make it available?
> > feeling
Thank you so much dean-dean. I was about to go nuts trying to figure what happened to my missing playback and recording devices.
    HP Pavilion dv7-1023cl
    Intel dual-core 7350 2.0 GHz
    GeForce 9600
    IDT
    17" laptop
    1920 X 1080
    320GB 5400 RPM
    Synaptic touchpad
    7 Mbits/sec
B
Bill Daggett
#15
tapceo <guest@xxxxxx-email.com> wrote:
>Your post is still having its affect dean-dean. Thank you. There should
>be a radio button to click for disabled items.
"dean-dean" left the room over two years ago.
