Re: Fedora 9: install attempts freeze
D
David Sanders
dryii wrote:
> I'm attempting to create a new virtual machine in Virtual PC 2007
> (6.0.156.0) for Fedora 9. I downloaded the DVD ISO last night. I
> created a new VM with 1GB of memory and 16GB disk. I can boot the VM
> and have successfully booted off the ISO image.
> The problem? No matter what options I put for booting (text vs GUI
> doesn't matter, either) the load stops around the following area:
> system 00:0c: iomem range 0x0-0x0 could not be reserved
> It doesn't stop on that line every time, but near/around that part of
> the boot process. When it hits the freeze, I have to reset the VM.
> CTRL-ALT-DEL doesn't work. I'm not getting the "unrecoverable
> processor error", but I did try adding the 'noreplace-paravirt'. It
> didn't help.
> Any suggestions on what I might try to get this loaded?
(1) Have you checked the sha1sum of the file you downloaded? Sounds
like a corrupt iso.
(2) Are you using Fedora-9-i386-DVD.iso or Fedora-9-i386-netinst.iso ?
(3) Whichever you are using, try the other one.
(4) It works here, but only with the noreplace-paravirt boot parameter.
You will need the same.
Good luck. David
B
Bob Babcock
What type of CPU do you have? I ran into the same problems with an Athlon
64 X2 5600+ (dual-core), but it seems to be working on an Athlon XP-A 2800+
(single-core). (Packages are being installed as I type this.) I did use
the noreplace-paravirt boot parameter. Assuming the install finishes, I'll
copy the VM to my dual-core machine and see if it works there.
B
Bob Babcock
Having built a Fedora 9 VM on a single-core AMD system, I find that I can
run it on my dual-core system without needing to provide any special boot
parameters. I have no idea why I can't do the install with dual-core, or
if that is even what causes the failure.
It's not quite right; video is messed up most places where the VM should be
in text mode.
D
David Sanders
I have a Pentium D. For an AMD processor I don't think you need
noreplace-paravirt, but I'm not sure.
B
Bob Babcock
David Sanders <news@xxxxxx> wrote in
news:OUToYy2EJHA.1268@xxxxxx:
Perhaps not. I just tried booting the Fedora 9 install DVD on my single-
core AMD system and it works with default parameters. Noreplace-paravirt
may change exactly where the dual-core system hangs the installer, but it
certainly doesn't make it work.
B
Bob Babcock
Bob Babcock <wssddc@xxxxxx> wrote in
news:Xns9B15E2F64593Awssddcgisnet@xxxxxx:
> single- core AMD system and it works with default parameters.
> Noreplace-paravirt may change exactly where the dual-core system hangs
> the installer, but it certainly doesn't make it work.
I made a list of valid boot parameters that I found in a Google search and
tried various combinations. I find that either
ide0=noprobe
or clock=pit
(or both) allow the installer to start. I cannot explain why these
seemingly very different parameters both work, nor can I explain why only
the installer needs them. I did not do an install, but I did take it
several screens into the GUI.
S
Silver1882
Thanks for the Ideal to get this to install
> ide0=noprobe
> or clock=pit
