Re: file names are changing?
D
Dave Patrick
I'd check the event log for clues. One thing that might trigger this is if
some permissions changed denying access to some or all of the profile
directory.
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
"lenny109" wrote:
> Hi,
> We have a sbs 2003 with also a TS server. Over the last week many of our
> login profiles seem to have become corrupted and when a user logs in they
> get a screen as if it is the first time they have logged in with only the
> basic icons and their individual settings not installed. In TSserver/users
> there have appeared two sets of folders for each user. The 'username'
> folder, which has always been there and also a new one called
> 'username(SERVERNAME)'. I have had to copy all the data from the
> 'username(SERVERNAME)' folder and transfer it into a new 'username'
> folder. This seems to have worked but I am sure something is wrong.
> This brings me to another point. Many files have also now copied
> themselves to the same location as the original but with the extra name in
> brackets e.g. 'filename(SERVERNAME)' attached and the original files are
> not opening. This is causing us major problems with the databases we run.
> What could be causing this? What can I do to stop it from happening? and
> is there a quicker fix than copying, pasting and deleting files?
> Cheers
> Lenny
D
Dave Patrick
You might want to download the diagnostic tools from the disk manufacturers
web site. Disk may be failing and or file system corruption.
Regards,
"lenny109" wrote:
> Hi,
> I can't find anything obvious id the event logs. I have just taken another
> look at the files though and they actually say 'filename (from
> Servername)'.
L
lenny109
I will do that but there is no other sign of disk failure occurring
including nothing on the event viewer. The rest of the system seems to be
working just fine. What about something to do with SugarSync online backup?
I have that installed on both computers. Today I have deleted the program
but of course it is too late.
"Dave Patrick" <DSPatrick@newsgroup> wrote in message
news:un95MYNfKHA.6096@newsgroup
> manufacturers web site. Disk may be failing and or file system corruption.
> Regards,
> "lenny109" wrote:
>> Hi,
>> another look at the files though and they actually say 'filename (from
>> Servername)'.
D
Dave Patrick
Not familiar with the product. You might look around and or ask them here.
http://support.sugarsync.com/ics/support/default.asp?deptID=4579&task=knowledge&questionID=361
Regards,
L
lenny109
Hi Dave,
You have sorted it. Thanks for the push in the right direction. I have
checked their help pages and it mentions exactly the problem I am having and
the reasons behind it. (not the cure though).
Thanks again.
Lenny
news:ubuF%231NfKHA.656@newsgroup
> Regards,
>>backup? I have that installed on both computers. Today I have deleted the
>>program but of course it is too late.
D
Dave Patrick
That's good to hear. Hopefully you can get them to come up with the fix.
Regards,
"lenny109" wrote:
> Hi Dave,
> and the reasons behind it. (not the cure though).
> Thanks again.
> Lenny
