L
Larry__Weiss
Are you running this from a cmd.exe prompt?
- Larry
On 5/19/2010 11:08 AM, Irwin wrote:
- Larry
> powershell "\\server\win7\netsetup\include\CreateShortcuts.ps1"
> %ausm%\Programs\System\SIW.lnk -target %programfiles(x86)%\SIW\siw.exe -work
> nevermind the %ausm%, but this is the error I get:
> The term 'x86' is not recognized as the name of a cmdlet, function, script
> file
> , or operable program. Check the spelling of the name, or if a path was
> include
> d, verify that the path is correct and try again.
> At line:1 char:152
> + \\bbx\win7\netsetup\include\CreateShortcuts.ps1 -link
> C:\ProgramData\Microsof
> t\Windows\Start Menu\Programs\System\SIW.lnk -target C:\Program Files (x86
> )\SIW\siw.exe -work C:\Program Files (x86)\SIW
> + CategoryInfo : ObjectNotFound: (x86:String) [], CommandNotFound
> Exception
> + FullyQualifiedErrorId : CommandNotFoundException
> I know it has something to do with the brackets (x86).. But question now is,
> how do I make it work?
