Re: How to change default folder layout?
  • Thread starter Zack Whittaker \(R2 Mentor\)
  • Start date
Z
What I've done, is if you press the Alt key I believe, you can see the menu
bar as in Windows XP. Also, if you open up a standard folder with files in
and arrange them the way you want, so in the details view and "Align to
grid", then go into the Folder Options and click the Apply to All Folders,
this should set up every folder in Windows to look like how you set it up
:o)
Zack Whittaker
Microsoft Beta (Windows Server R2 Beta Mentor)
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: http://msblog.resdev.net
» ZackNET Forum: www.zacknet.co.uk/forum
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, mother or cat. Let's be clear on that one!
A
Adahn
"Apply to All Folders" is not with us anymore :(
"Zack Whittaker (R2 Mentor)" <[email protected]> wrote in message
news:[email protected]
> menu bar as in Windows XP. Also, if you open up a standard folder with
> files in and arrange them the way you want, so in the details view and
> "Align to grid", then go into the Folder Options and click the Apply to
> All Folders, this should set up every folder in Windows to look like how
> you set it up :o)
