Re: Instalation of 5308
T
teri dickinson
I get the exact same error. I've to a Feb CTP DVD hard copy for the VIP
program as well as the downloaded iso. I get the same error on two different
types of workstations with intel chip sets, IDE drives and 1 GB of Ram. I
tried a VMWare machine using a SCSI driver and followed the instructions
about using the command prompt to create a primary condition and that install
failed as well.
Could this be an issue with the version I have?
thanks
teri
"Andre Da Costa" wrote:
> What is the amount of physical memory in the Host machine? Windows Vista
> requires a minimum of 300 MBs of RAM if you want to install it Virtual PC,
> more is probably a good idea. Most persons I know running it in VPC are
> using ranges of 768 to 1.2GBs of RAM for Virtual Machines with Vista 5308.
> Andre
> Windows Connect | http://www.windowsconnected.com
> Extended64 | http://www.extended64.com
> Blog | http://www.extended64.com/blogs/andre
> http://spaces.msn.com/members/adacosta
> "spp" <[email protected]> wrote in message
> news:[email protected]
> >I can't install vista on Virtual PC 2004
> > When appars Type product key for activation I get an setup.exe error "The
> > instruction at 0x1fee7a6d referenced memory 0x02c5bd0f.
> > The required data was not placed into memory because of an I/O error
> > status of 0xc0000010
