M
_mikebs
Yes, I think this is a bug, I've tried everything I can think of to get the
preview to show, but it just won't unless you double click to open the mail.
I hate to do that because I've been getting a lot of worms lately [hopefully
caught by AVG Free] some of them not even caught as junk. I doubt if this
is a new enhancement. You can find other issues using the 'find a message'
box or search for them. If no one else seems to report this, you might want
to click on the Help button and select Get technical support for the report
form. Thanks.
Mike BS - Windows XP Pro 5.1.2600.2180 SP2_rtm.040803-2158 - IE:
7.0.5730.11 - WLM 12.0.1606.1023
_____
"ElectricSlushie" <[email protected]> wrote in
message news:[email protected]
form. Thanks.
_____
> I was wondering if anyone else was having the following issue.
> Whenever I check my mail in the regular Inbox, I can easily see the
> message
> listings above and the message box itself below. Whenever I go to my Junk
> Mail Inbox, I do not. All I see is a list of the mail in the folder with
> no
> message window; despite my clicking/highlighting a message. Despite my
> efforts to apply the settings of the list on top and the window on bottom
> for
> all folders, it seems to fail with the Junk folder. My only option is to
> open
> the male in a separate window. That is fine for the time being (although I
> personally consider it to be rather cumbersome to do so every time I want
> to
> open an e mail!!) even though I had no problem before with it. The only
> thing
> I've done differently was install a newer version of Live Mail Desktop
> because it was not syncing last night.
> So....
> If anyone else is having this problem, or has a solution, I'd really like
> to
> know.
