Re: Live Messenger on XP x64
R
Ray Li
Runs good here too.
"Jonathan Kay [MVP]" wrote:
> Hi,
> 8.5 runs fine on my Windows Server 2008 x64 as well.
> Jonathan Kay
> Microsoft MVP - Windows Live Messenger/MSN Messenger/Windows Messenger
> Associate Expert
> http://www.microsoft.com/windowsxp/expertzone/
> Messenger Resources - http://messenger.jonathankay.com
> All posts unless otherwise specified are (c) 2007 Jonathan Kay.
> You *must* contact me for redistribution rights.
> "BENAGLIA" <[email protected]> wrote in message
> news:[email protected]
> > I'm running version 8.1 on both Xp 64 and Vista 64 and works just fine on both.
> > AndyB
> > "mjs" <[email protected]> ha scritto nel messaggio
> >> Well, the Beta link Jonathan provided won't even install the darn thing on x64. It hangs
> >> at the file decompression stage. Guess I'll try the 8.1 next.
> >> "Jane C" <[email protected]> wrote in message
> >>> Hi mjs,
> >>> There is no native x64 version of Windows Live Messenger. The standard 32 bit version
> >>> runs fine on x64.
> >>> Jane, not plain ;) 64 bit enabled :-)
> >>> Batteries not included. Braincell on vacation ;-)
> >>> MVP Windows Shell/User
> >>> "mjs" <[email protected]> wrote in message news:%[email protected]
> >>>> But are these links to 64-bit proprietary versions, or the same versions that run on
> >>>> 32-bit XP and Vista?
> >>>> I am looking for a 64-bit version of Live Messenger.
C
Carl Jack
> Greetings,
> 8.1 should work fine:
> http://microsoft.com/downloads/details.aspx?FamilyID=d78f2ff1-79ea-4066-8ba0-ddbed94864fc
> If you're looking for 8.5 beta, you'll need the MSInstaller file directly, like from here:
> http://www.msgstuff.com/downloads/download/135/
> Jonathan Kay
> Associate Expert
> "mjs" <[email protected]> wrote in message news:[email protected]
> > Can someone give me a direct link to the latest XP x64 compatible version of Live
> > Messenger?
C
Carl Jack
Mux it, I get a firewall error on window xp 64 bit
WLM on my other computer (right next to this one) works, and they are both
connected to the same router. What is the problem and solution?
we were unable to sign you into WLM......
Error Code 80048820
extended error code: 80048412
The only firewall is windows firewall and this installation is brand new,
the only thing on it: firefox, sp2 xp64, video and audio drivers, and LAN
> that run on 32-bit XP and Vista?
> "Jonathan Kay [MVP]" <[email protected]> wrote in message
> > Greetings,
> > like from here:
> > Jonathan Kay
> > Associate Expert
> >> of Live Messenger?
D
Dennis Pack
Carl Jack:
If you have a motherboard with a Nvidia chipset, install the Nvidia
firewall then uninstall it to remove a hidden firewall.
Dennis Pack
XP x64 SP2, Vista Enterprise x64 SP1
WHS, Office Professional Plus 2007 SP1
"Carl Jack" <Carl [email protected]> wrote in message
>> Greetings,
>> Jonathan Kay
>> Associate Expert
>> > version of Live
>> > Messenger?
T
Tritous
Thanks for that Jonathon. Personally I'm tired of being put into these
unforgivable situations: A mandatory update when the installer claims it's
not compatible with the OS and 8.1 is no longer accepted.
I never saw why the upgrades had to be mandatory anyway, especially not when
I've seen so many complaints about the interface change.
I still cannot get it to run: After running the msi file you offered I
STILL get the complaint that a new version is required, but messenger states
it is running V2008 build 8.5.1288.826. I am running Xp64 with all the
updates for that of course.
> Greetings,
> Jonathan Kay
> Associate Expert
> > Messenger?
J
Jonathan Kay [MVP]
Greetings,
This is an old post from two years ago and obviously is no longer valid.
See here on my blog for something new:
http://messengergeek.spaces.live.com/blog/cns!E3785B1281BBDA1!3406.entry
Jonathan Kay
MessengerGeek Blog: http://www.messengergeek.com
Messenger Resources: http://messenger.jonathankay.com
(c) 2009 Jonathan Kay - If redistributing, you must include this signature or citation
"Tritous" <[email protected]> wrote in message
>> Greetings,
>> Jonathan Kay
>> Associate Expert
>> > Messenger?
T
Tanya
Good Morning
I tried both option one and two and keep getting an error message that will
not let me log in...what can i do now...as this is something i need for work
as it is a way the bosses communicate with me...
Thank you
> Greetings,
> Jonathan Kay
> >> Greetings,
> >> Jonathan Kay
> >> Associate Expert
> >> > Messenger?
Z
Zootal
I was able to get it working using the links from the page Jonathan posted
below.
One solution is to use Yahoo messenger - it will let you connect to MSN
messenger accounts. Since Microsoft doesn't want us to use MSN messenger,
I'm happy to oblige them and use someone else's product. Besides, I don't
really like the Vista/Win7/Office7 interface styles anyhow - I prefer my
menus across the top of the app like they have been for the past 20 years or
so. Change for the sake of change is not always a good thing, and Yahoo
hasn't *yet* gone down the newMicrosoft UI path.
Trillian (trillian.cc) is another option. It lets you connect to all kinds
of accounts, including msn, yahoo, myspace, twitter, etc. and you can login
with multiple accounts. In the past they had some rather serious stability
problems. I'm using the new version now in the hopes that they fixed some of
the old bugs.
I used to use Web Messenger - unfortunately, they discontinued it, and the
web based live messenger they replaced it with is horrid. I loved
WebMessenger, I used it all the time at work, I wish it was still available.
"Tanya" <[email protected]> wrote in message
> Good Morning
> will
> work
> Thank you
>> Greetings,
>> Jonathan Kay
>> > it's
>> > when
>> > states
>> >> Greetings,
>> >> Jonathan Kay
>> >> Associate Expert
>> >> > version of Live
>> >> > Messenger?
D
Dana
Jonathan,
First, thank you for taking the time to provide messenger help to those of
us running XP x64.
I followed your directions at the above blog, for installing the latest
messenger (Version 2009 Build 14.0.8089.726), and it seemed to work well for
the most part, however I immediately began experiencing frequent problems
with my computer entering / leaving standby mode after completing this
installation. Nothing else has been changed / installed on the computer in
the recent past, so I believe I am safe in assuming the problem is related to
this WLM install. Have you heard of others having a similar problem, and
would you be able to offer any help in debugging the issue? I do have an
error code signature, if it is of any help.
Thank you.
D
Dana
Jonathan,
First, thank you for taking the time to help us XP x64 users with our Live
Messenger issues. I followed the steps outlined in your blog, downloading
and installing the files in the prescribed order. It has worked well, except
ever since that day my computer has had issues going into and out of sleep
mode. Because nothing else was changed in the computer configuration in the
last few months, and the appearance of this new problem coincided with the
installation of WLM 2009, I feel I am safe in assuming that is the cause of
this new problem.
Have you heard of any other users having a similar problem? Are you able to
help me debug this issue?
Thank you,
Dana
D
Dana
> Jonathan,
> this new problem.
> Thank you,
> Dana
Cannot tolerate the constant hang-ups getting into and out of standby mode
any longer. I must uninstall this. Jonathan, do you have any uninstall
procedure for this hack of an install?
Thank you,
Dana
J
Jonathan Kay [MVP]
Greetings,
Uninstall for each component of the Live suite (including Messenger) is listed here:
http://messengergeek.spaces.live.com/blog/cns!E3785B1281BBDA1!3332.entry
Alternatively you can just save the existing MSI files somewhere like the Desktop,
right-click on them and choose Uninstall there.
Jonathan Kay
(c) 2010 Jonathan Kay - If redistributing, you must include this signature or citation
"Dana" <[email protected]> wrote in message
>> Jonathan,
>> this new problem.
>> Thank you,
>> Dana
> Thank you,
> Dana
B
Bobby Johnson
Did anyone ever note that Windows Live Essentials, which includes
Messenger, is not supported on XP x64?
Windows Live Essentials require the following:
* Operating system: Windows XP with Service Pack 2 (32-bit edition
only), Windows Vista (32-bit or 64-bit editions), Windows 7 (32-bit or
64-bit editions), or Windows Server 2008.
I think it states XP 32-bit only. There's a high probability this may
account for the unusual on XP x64 (64-bit)!
On 2010-05-03 15:27, Jonathan Kay [MVP] wrote:
> Greetings,
J
Jonathan Kay [MVP]
It's more than noted, it won't even let you install unless you do it manually.
Jonathan Kay
"Bobby Johnson" <[email protected]> wrote in message
> Did anyone ever note that Windows Live Essentials, which includes Messenger, is not
> * Operating system: Windows XP with Service Pack 2 (32-bit edition only), Windows Vista
> (32-bit or 64-bit editions), Windows 7 (32-bit or 64-bit editions), or Windows Server 2008.
> I think it states XP 32-bit only. There's a high probability this may account for the
>> Greetings,
