Re: merge CSV to excel
T
Tom Lavedas
On Oct 22, 12:35 pm, "Ammy" <vbsstr...@xxxxxx> wrote:
> Can anybody help me withe this script.
> I want comma seperated files (; ) import it to excel.
> The script is ok but the data could not split in the rows, i must change
> that in excel.
> Like Extra >>Text to coloms.
> Thanks,
> Ammy
> filename001.csv
> data;data;data;data;data;data
> Here is the script :
Since your file is NOT comma delimited, their are only two things I
can think to do; change the delimiter in the file to commas or use an
Excel data import in place of the open. Here is a macro I recorded in
Excel, with the extra bits stripped out and some other changes to make
it VBS compatible. Its up to you to install in in your script ...
Sub Macro2()
' Macro2 Macro
' Macro recorded 10/22/2008 by Tom Lavedas
sFileSpec = "C:\Someplaceuseful\test.csv"
With ActiveSheet.QueryTables.Add("TEXT;" & sFileSpec, Range("A1"))
.AdjustColumnWidth = True
.TextFileStartRow = 1
.TextFileParseType = 1 ' xlDelimited
.TextFileSemicolonDelimiter = True
.Refresh BackgroundQuery:=False
End With
End Sub
Tom Lavedas
http://members.cox.net/tglbatch/wsh/
L
>> that in excel.
>> Thanks,
>> Ammy
>> filename001.csv
CSV is the commonly known name for comma delimited, or not?
> Sub Macro2()
> ' Macro2 Macro
the line above makes it semicolondelimited ... ;-)
> End With
> End Sub
> Tom Lavedas
Luuk
L
>>> that in excel.
>>> Thanks,
>>> Ammy
>>> filename001.csv
>> Sub Macro2()
>> ' Macro2 Macro
>> End With
>> End Sub
>> Tom Lavedas
oh, i forgot to mention that ist quit common in the Netherlands to have
semicolon separated files because we do everything with a decimal comma
so 2/3 is not 0.6666667 but is 0,6666667
Luuk
