Re: NASCAR RACING 2003
T
Tony M
Installed and plays beautifully on a clean load of RC1 - Did not have to
even adjust it to run in compat mode or set it to disable DWM
Works flawless - Much Much Much better than EA Sport Nascar SimRacing -
which is so trying to be this game and even though it may look prettier - It
does not work on Vista at all - Thanks EA.... Papyrus is no more, but still
after 3 years has a better game!
Tony Maynard, MCSE+I
Windows Vista Ultimate RC1 - 32bit
"imacken" <[email protected]> wrote in message
news:[email protected]
> Thanks for making me feel worse, Tim!
> Seriously though, I'm running on Athlon x2 4400, X1900XT, Audigy, latest
> betas from ATI and Creative, DirectX @ 1280x1024.
> I've tried turning all visual elements off, and disabling sound, but still
> just crashes when it tries to get to car/track.
> This is driving me mad as it's my favourite game!
> Iain
> "Tim Payne" wrote:
>> I just installed it now and it runs fine for me. It gives an error
>> message
>> at the start about disabling some visual elements temporarily since the
>> "program is not compatible with Windows", but I don't see any issues.
>> My system is a P4 3.2, Asus P4P800SE, Radeon 9600XT, Audigy 2ZS, running
>> the
>> latest Vista beta drivers from ATI and Creative. In the game I chose
>> What are you running?
>> > Anyone managed to get my favourite game working? With me, it loads OK
>> > until
>> > it actually tried to go to the track/car - then it just crashes.
>> > Any ideas?
I
imacken
Great for you Tony! Unfortunately, that doesn't help me with my problem, does
it?
> "imacken" <[email protected]sions.microsoft.com> wrote in message
> > Iain
> >> message
> >> the
> >> > until
> >> > Any ideas?
T
Tony M
No it does not help you, other than to answer your question if the game
works. I will assume that your issues are hardware/driver related. There is
no other reason as to why the game would work on my system and not yours
other than the difference of hardware and its driver support
I will list my system specs so that you may make a base comparison. Good
luck getting this fantastic game to work -
Dell Dimension 4700
P4 3Ghz HT enabled
2GB DDR2 - 4200
160GB SATA Drive
Creative Labs SB Live! 24Bit - Latest Vista drivers
ATI Radeon x700 Pro PCI-E x16 - Microsoft WDDM drivers
TechBeta Tester
> does
> it?
>> It
>> still
>> > latest
>> > still
>> > Iain
>> >> message
>> >> the
>> >> running
>> >> the
>> >> > OK
>> >> > until
>> >> > Any ideas?
I
imacken
Hi Tony! I'm just incredibly jealous that you have it working! I love that sim.
We have very similar setups.
I have AMD64 x2 4400
2Gb DDR2
160Gb SATA drive
ATI x1900XT with latest ATI drivers (I've also tried Windows WDDM)
Creative Labs Audigy with latest Creative drivers.
I really wish that I could get this to work! It's the only game/app that I'm
struggling with on Vista.
> Dell Dimension 4700
> P4 3Ghz HT enabled
> 2GB DDR2 - 4200
> 160GB SATA Drive
> TechBeta Tester
> > does
> > it?
> >> It
> >> still
> >> > latest
> >> > still
> >> > Iain
> >> >> message
> >> >> the
> >> >> running
> >> >> the
> >> >> > OK
> >> >> > until
> >> >> > Any ideas?
T
Tony M
Did you do a clean install of Vista?
x86 or x64
I found that after I installed the latest ATI drivers, that my directx games
had corrupt textures... even when reverting back to the WDDM driver.
I did a clean install and just left the Microsoft driver installed, and it
worked perfectly out of the box... now you do have a new generation chip
with the X19xx card...Im still on the X7xx series... possibly the drivers in
box dont support the feature set of your card as its too new.
> sim.
> 2Gb DDR2
> 160Gb SATA drive
> I'm
>> is
>> Dell Dimension 4700
>> P4 3Ghz HT enabled
>> 2GB DDR2 - 4200
>> 160GB SATA Drive
>> TechBeta Tester
>> > problem,
>> > does
>> > it?
>> >> to
>> >> SimRacing -
>> >> prettier -
>> >> It
>> >> still
>> >> > latest
>> >> > still
>> >> > Iain
>> >> >> message
>> >> >> the
>> >> >> issues.
>> >> >> running
>> >> >> the
>> >> >> chose
>> >> >> > loads
>> >> >> > OK
>> >> >> > until
>> >> >> > Any ideas?
I
imacken
Interesting Tony! No, it wasn't a clean install, it was an upgrade. I also
noticed that whenever I installed the latest ATI drivers for RC1 that other
games had texture corruption that weren't there in Beta 2 and the appropriate
drivers.
However.... I tried a clean install of RC1 earlier, and I just got a system
reboot when it reached 21% of 'expanding files', then a BSOD.
I tried again with no luck. So, I'm back to XP until I can find a solution
to why my RC1 won't install!
> x86 or x64
> > sim.
> > 2Gb DDR2
> > 160Gb SATA drive
> > I'm
> >> is
> >> Dell Dimension 4700
> >> P4 3Ghz HT enabled
> >> 2GB DDR2 - 4200
> >> 160GB SATA Drive
> >> TechBeta Tester
> >> > problem,
> >> > does
> >> > it?
> >> >> to
> >> >> SimRacing -
> >> >> prettier -
> >> >> It
> >> >> still
> >> >> > latest
> >> >> > still
> >> >> > Iain
> >> >> >> message
> >> >> >> the
> >> >> >> issues.
> >> >> >> running
> >> >> >> the
> >> >> >> chose
> >> >> >> > loads
> >> >> >> > OK
> >> >> >> > until
> >> >> >> > Any ideas?
