RE: New Realtek HD Audio Drivers (ver. 1.91 22 April 2008)
P
peter c.a.hawkins
Hello ,Are you finding that the HD icon does not load in the taskbar?
"Cal Bear '66" wrote:
> New Realtek HD Audio Drivers (ver. 1.91 22 April 2008):
> http://www.realtek.com.tw/downloads...=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
> Add/Fix
> 1.) Driver :
> 1. Fix DTM 1.2 KS topology test fail issue.
> 2. Customizations.
> NOTE: There is now a disclaimer before you can download the drivers that it is
> best to obtain new drivers from your computer/motherboard manufacturer since
> they may have made customizations to their hardware; although, I personally have
> never had a problem with the drivers downloaded directly from the Realtek site.
> I Bleed Blue and Gold
> GO BEARS!
P
peter c.a.hawkins
How strange,mine will not load .it only appears if i click on hd manager in
the control panel.not to worry.
> No, the Realtek HD Audio Manager red speaker icon always seems to load on every
> reboot here.
> GO BEARS!
> "peter c.a.hawkins" <petercahawkins@xxxxxx> wrote in message
> news:1F670F27-9654-4930-9567-256D149C328B@xxxxxx
> >> Add/Fix
> >> 1.) Driver :
> >> 2. Customizations.
> >> is
> >> have
> >> site.
> >> GO BEARS!
T
Check if resetting the icon to display fixes the icon loading. Open the
HD Audio Manager and click the information icon. Toggle the setting
to Display icon in the notification area.
>> reboot here.
>> GO BEARS!
