R
Roman
"RMWChaos" wrote:
> Oblivion runs fine here too. Thought I read on the Oblivion site that the
> patch was not for x64 systems. Are you running any kind of system monitoring
> software or hardware like ASUS Probe? These periodically poll the system, and
> I have seen delays in games because of it. Try disabling all your other apps
> first, then run Oblivion. Also, try setting your video options down to
> minimum and work your way up. Should be smooth sailing for you at lowest
> video settings.
> My config for reference:
> Vista x64 Beta 2
> ASUS A8V, onboard audio and LAN
> AMD Athlon 64 X2 4400+
> 1GB Corsair PC2700 (2x 512MB)
> 80GB Maxtor UDMA ATA133 HDD
> BFG GeForce 7800GSOC 256MB (using nVidia Vista x64 beta driver)
> -Rob
> "Paul Smith" wrote:
> > "Roman" <[email protected]> wrote in message
> > news:[email protected]
> > > All,
> > > I've got a problem with Oblivion. The game runs very jerky, ok for a few
> > > seconds, then freeze for a few seconds, runs for a few seconds, then
> > > freeze
> > > for a few seconds...
> > > Running Vista 64
> > > A8N-SLI-SE
> > > AMD Athlon 64 3000+
> > > 1Gb RAM
> > > nVidia GF 7300GS PCIe (running MS WDDM driver)
> > > I've not played the game yet and I'm really keen to start. I've applied
> > > the
> > > v1.1 game patch. I did get a dialog box during install saying it couldn't
> > > identify the video card. I did have nVidia drivers but uninstalled them
> > > because I couldn't get the 3D windows without the MS WDDM drivers. Any
> > > thoughts? Maybe I need to wait until MS release an update to the 64 bit
> > > beta
> > Oblivion runs fine here but I'm using a Radeon 850XT PE with ATI's drivers.
> > My only thoughts are to boot XP to play it. 8-) nVidia's drivers to seem to
> > be having a lot of issues.
> > Paul Smith,
> > Yeovil, UK.
> > Microsoft MVP Windows Shell/User.
> > http://www.windowsresource.net/
> > *Remove 'nospam.' to reply by e-mail*
> video settings.
> Vista x64 Beta 2
> -Rob
> > > All,
> > > freeze
> > > Running Vista 64
> > > A8N-SLI-SE
> > > AMD Athlon 64 3000+
> > > 1Gb RAM
> > > the
> > > beta
> > Paul Smith,
> > Yeovil, UK.
