G
Guest
I've been having a devil of a time attempting to update my Windows Live
installs by using the most recent release from http://get.live.com/. I've
been repeatedly getting the message:
"There was a problem with this installation. Windows Live Suite was not
installed.
System error details
Code: 0x80070643
Description: Fatal error during installation"
I saw your suggestions in this forum, and noted that on my machine, which
runs Windows XP SP2, there IS NOT a "C:\Documents and Settings\All
Users\Application Data\WLInstaller" folder. Any ideas why that might be? I'm
also noting that within the other two log folders, the logs date back to
August and haven't been modified since! I've downloaded and run the
WLInstaller.exe quite a few times since then!
I'm a tad concerned as although I first had a problem with the Windows Live
products, it now seems that other Microsoft and non-Microsoft products that
use the Windows Installer, now all have trouble installing. I suspect a
common problem now affects them all. I've tried (re)updating the Windows
Installer 3.1 (v2), to no avail.
Any ideas appreciated.
Thanks,
MS
"Peter" <[email protected]> wrote in message
news:[email protected]
installed.
Code: 0x80070643
Thanks,
MS
> Hi tembelus, you mentioned in your previous thread that you had fixed
> the installation problem. Is that not really the case or is this problem
> different? So the installation is still not completing I gather. There
> seems
> to be something unique about your Operating System that is causing your
> installation problem. I have not tested 'Windows Live Beta Remover' so I
> do
> not know exactly what it does, although the information at
> http://windowslivewriter.spaces.live.com/ indicates that it definitely
> removes the Windows Live installer, specifically to address issues of
> conflicting languages with other Windows Live Beta products. Thus,
> according
> to the release notes of Windows Live Beta 2.0 at
> http://get.live.com/en-us/betas/installer_release_notes "If you install
> any combination of the Messenger, Mail, or Writer betas on one computer,
> each beta must be the same language version. If you try to install one of
> these betas in a different language, the installation will fail."
> So tell us what language version you are trying to install. What are
> the
> language versions of your other Windows Live Beta products (if any). What
> operating system are you using? What anti-virus product are you using?
> As implied at http://windowslivewriter.spaces.live.com/ the
> installation logs can help debug the installation problem.
> If you are using Windows XP (SP2) the log files are located at the
> following
> locations:
> C:\Documents and Settings\All Users\Application
> Data\WindowsLiveInstaller\logs
> Data\WindowsLiveInstaller\MsiLogs
> C:\Documents and Settings\All Users\Application Data\WLInstaller
> If you are using Windows Vista the log files are located at the following
> locations:
> C:\programdata\WindowsLiveInstaller\logs
> C:\programdata\WindowsLiveInstaller\MsiLogs
> C:\programdata\WLInstaller
> Open these files with Notepad and see if you can find an indication of
> what
> is halting the installation process.
> Cheers,
> Peter
> (Windows XP Pro SP2)
> "There are more things in Heaven and earth, Horatio, than are dreamt of in
> your philosophy." - Shakespeare
> __________________
> "tembelus" <[email protected]> wrote in message
> |i use wlmd and wlm and my two programs beta.and i have some problem if i
> | install wlmd i don't install wlm if i opposite way wlmd don't install.i
> used
> | beta removed and i install again i had same problem.ok i used two beta
> | programs(wlmd-wlm),what can i do?
> | help me ...
