S
Silverhawk
same issue i had with BF2 first I simply right clicked the shortcut and ran
as admin then once I saw that working i changed access rights to the program
"Jonty" wrote:
> Cameron,
> Go the the folder where FS is installed, right click the executable file and
> try run as administrator to see if you have a security issue.
> Jonty
> "MAX" wrote:
> > Hi Cameron,
> > dont you have 2 HD (sata)?
> > if you dont have, get one extra and install Vista on this HD
> > Vista is still BETA !!!
> > I have 2 HD 1 XP and 1 Vista so I can test it first
> > its a bracked where i can change the first disk
> > so I dont have to worry about my data
> > you can allways burn it to a dvd!
> > MAX
"Jonty" wrote:
> Cameron,
> Jonty
> "MAX" wrote:
> > Hi Cameron,
> > MAX
