Re: Pls help, New notebook preinstalled with vista keeps freezing
R
Rick Rogers
> Is it my laptop or vista??
Or something else? It could be faulty hardware, it's unlikely to be the
Vista installation (manufacturers typically use an image and compatible
hardware). If it only happens when surfing the 'net, then I'd suspect that
you have already downloaded and installed an IE plug-in that is causing a
problem. If you know for sure that you haven't, then I'd be more inclined to
think it's hardware related, and you should take it straight back and have
it replaced.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"titangal27" <indianlacewigs@yahoo.com> wrote in message
news:titangal27.2my8l0@no-mx.tabletquestions.com...
> Hi guys, I bought a new acer notebook today and it came preinstalled
> with vista.
> I got the acer aspire 5610-2328, intel pentium dual core processore,
> and it has a lot of space 120 gb, and 1gb so I know space is not a
> problem.
> I've only been using it for a couple of hours and it has already FROZEN
> 5 times. Yes 5 times. The last time, it froze right after it finished
> booting. The only thing I'm doing when it freezes is surfing the net
> with IE.
> And ctrl atl del doesn't work either when it freezes. I press those
> buttons and nothing happens, so I have to reboot the notebook.
> What's the problem? Is it my laptop or vista?? Thanks.
> titangal27
