Re: Printer Support
R
Robert Aldwinckle
(crosspost added to Vista Printing NG)
"Stewart H. Spanier" <[email protected]> wrote in message
news:[email protected]
Stewart,
Your headers show you're using a web interface to newsgroups.
Which portal (URL) are you using? If it lists the newsgroup I added
you may be able to enter it just by clicking on the link to it in the header
of my message.
> What alternatives do I have?
Do your two OS share drives?
Something I would try if you don't get any better ideas
would be printing to file and then printing the file with the
OS which can operate your printer. Actually I suppose
another possibility on the same tack would be emailing
yourself the file and then receiving it and printing it on
the other system.
HTH
Robert Aldwinckle
>I took this past weekend to configure Windows Vista Beta 2 (WVB2). I am
> growing to like it save for printer support. I have an HP printer and have
> spoken with them via email. They have no plans to support WVB2 and will not
> support until formal release of the product. Now I do need to print. The XP
> driver fails for my printer at the installation point of the operating
> system saying invalid parameter. I think WVB2 thinks its related to a browser
> installed on my system I can not find using registry editors and search.
> (T-Mobile something. I go to the site recommended at it is in german). Since
> the XP driver won't work, What alternatives do I have?
> Would a file from a valid XP disk serve to provide support for printing?
S
Stewart H. Spanier
Thank you for your assistance with the ideas you provided. I have one
operating system on my computer. I took the plunge and went to Beta2. It
seems to be functional except for the printing aspect. What I may very well
end up doing is reinstalling after I put the printer driver back on and
"upgrade."
Respectfully,
Stewart H. Spanier
> Stewart,
> of my message.
> the other system.
> HTH
> Robert Aldwinckle
