Re: Remove extra Double codes from CSV Files (vb Script Language)
T
Tom Lavedas
On Nov 16, 6:20 am, Learn4Develop
<Learn4Deve...@newsgroup> wrote:
> On daily bases I have received files with double quotes comma separated, but
> in some records I found 2 times double quotes and some time different squence
> of double quotes placements.
> I just want to remove all unnecessary (extra) double quotes (see the
> following values where i want to remove extra double quotes.
> "0123x",""Company D-Val"","Class D, sector N","DD5894"
> "4894D",""Recycle" Rubbish, C class","Class D, Sector F, Block N","D870GH"
> "AB8679",""AB Ltd"",""Need" Clean Drive Way, stores","GF0347"
> I am looking the output like that.
> "0123x","Company D-Val","Class D, sector N","DD5894"
> "4894D","Recycle Rubbish, C class","Class D, Sector F, Block N","D870GH"
> "AB8679","AB Ltd","Need Clean Drive Way, stores","GF0347"
{snip}
It was tricky getting the indexing right, but this seemed to do what
you want on the test sample you provided ...
Do Until inFile.AtEndOfStream
record = InFile.ReadLine
nPos = Instr(record, Chr(34) & Chr(34))
do while nPos > 0
record = Left(record, nPos - 1) & Mid(record, nPos + 1)
nPos = Instr(nPos + 1, record, Chr(34))
nPos = Instr(nPos + 1, record, Chr(34) & Chr(34))
loop
outFile.WriteLine record
Loop
The approach removes the first of a pair of double quotes and the very
next double quote that follows; thereby removing the starting and
ending quotes that enclose text, when there are too many.
_____________________
Tom Lavedas
L
Learn4Develop
> {snip}
> do while nPos > 0
> loop
> Loop
> Tom Lavedas
Hi Tom
Thanks for the code, its working fine with the above criteria, but gives
me error if there is Null value between double quotes ("") i.e.
("AB8679","""",""Need" Clean Drive Way, stores","")
As i have some columns in CSV file where the value is Null "". How i can
resolve it.
Thanks again for your great help.
P
Pegasus [MVP]
"Learn4Develop" <Learn4Develop@newsgroup> wrote in message
news:70A7DE23-C1A4-417B-9B34-E0BA09CDF49C@newsgroup
>> > separated, but
>> > squence
>> > N","D870GH"
>> > N","D870GH"
>> {snip}
>> do while nPos > 0
>> loop
>> Loop
>> Tom Lavedas
> Hi Tom
> resolve it.
Try my suggestion. It should beable to cope with empty fields.
T
Tom Lavedas
On Nov 17, 11:46 am, Learn4Develop
> > > in some records I found 2 times double quotes and some time differentsquence
{snip}
> Hi Tom
> resolve it.
Try this (though Pegusus' approach is also workable) ...
do while nPos > 0
record = Left(record, nPos) & Mid(record, nPos + 2)
if nPos > 0 then
else
record = record & Chr(34)
end if
loop
Loop
Tom Lavedas
T
Todd Vargo
Learn4Develop wrote:
> Hi Tom
> resolve it.
ISTM, only strings containing a comma should need quoted. But since you say
it gives you an error, it begs the questions. What is giving the error? And
what is creating these incorrect csv files?
Todd Vargo
(Post questions to group only. Remove "z" to email personal messages)
