Re: Restricted sites - Setting Internet Options
P
PA Bear [MS MVP]
[Forwarded to Vista Mail newsgroup via crosspost]
Your settings in IE Tools | Internet Options | Security | Restricted Sites
(zone) have nothing to do with the mail you receive or don't receive in
Windows Mail client. The emails you *open* are subject to Restricted Sites
zone settings by default.
Create Message Rules In Windows Mail (Vista)
http://www.lockergnome.com/windows/2006/11/27/create-message-rules-in-windows-mail-vista/
Block Messages (Block Senders) in Windows Mail
http://www.lockergnome.com/windows/2006/11/24/block-messages-in-windows-mail-vista/
~Robear Dyer (PA Bear)
MS MVP-IE, Mail, Security, Windows Desktop Experience - since 2002
AumHa VSOP & Admin http://aumha.net
DTS-L http://dts-l.net/
Roderunr wrote:
> I have entered a number of URLs from Emails that I dfo not want to
> receive.
> I have tried a variety of variationbs including the (all inclusive "*."
> Some sites remain blocked others still get through. I'm using Vista Home
> Premium; mail is Windows Mail, and of course IE 7. Would appreciate any
> suggestions. This is a really annoying problem. I've also used the "Junk
> Mail" optionb to "block sender's domain". That doesn't work either.
> THANKS!!
