R
Robbin Meng [MSFT]
Hello Harry,
Thanks for your post and others' suggestions.
In addition to checking SBS BPA report and system disk space, did you notice that the Microsoft Exchange System Attendant is set to Automatic and started? Does the issue still
occurs if you manually restart the Exchange System Attendant service?
BTW, please check and make sure the latest Exchange server 2007 SP2 is applied. Also, please temporarily disable all 3rd party anti-virus/anti-spam software as incorrect
configuration of these software may cause Exchange engine to crash.
Overview of Exchange Server 2003 and antivirus software
http://support.microsoft.com/kb/823166/en-us
Hope this helps.
Best regards,
Robbin Meng(MSFT)
Microsoft Online Newsgroup Support
Please post your SBS 2008 related questions to the SBS newsgroup on Connect website:
https://connect.microsoft.com/sbs08/community/discussion/richui/default.aspx
Please post your EBS related questions to the EBS newsgroup on Connect website:
https://connect.microsoft.com/ebs08/community/discussion/richui/default.aspx
If you want to use a newsreader other than a web forum to access these newsgroups,
please refer to the following blog to apply NNTP password and configure a newsreader:
http://msmvps.com/blogs/bradley/archive/2008/11/02/signing-up-for-the-sbs-2008-newsgroups.aspx
When responding to posts, please "Reply to Group" via your newsreader so
that others may learn and benefit from your issue.
Hope this helps.
Best regards,
Robbin Meng(MSFT)
