M
_mikebs
Yes, I think they are left, [I can't find the account options to check on
it] but why not just download and forget recovering extraneous stuff? I
think it might be related to deleting in Quick views [which is still not
fixed]. My count before compaction is now over 500 and climbing. Maybe I
can avoid wholesale recovering.
Thanks, Mike - Windows XP Pro SP2 WLM 12.0.1606.1023
_______________________________________________
"Peter.R" <[email protected]> wrote in message
news:[email protected]
> Have you got your account options set to leave a copy of your messages
> on the server? If so, it could be that they are all being downloaded again
> after the recovery, hence the duplicates.
> Cheers,
> Peter
> (Windows XP Pro SP2 with Windows Live Mail 12.0.1606)
> "There are more things in Heaven and earth, Horatio, than are dreamt of in
> your philosophy." - Shakespeare
> "_mikebs" <[email protected]> wrote in message
>> The question still remains! Why does this keep happening? Most of the
>> Recovered items I've had were mail that was deleted maybe after or during
>> the problem which were copied to a new inbox there and some Sent items
>> copied to a new Sent items in Recovered items which appear to be exact
>> duplicates of the Sent item in my individual accounts. It sounds like
>> they
>> are mostly duplicates and I haven't had many problems displaying any
>> e-mail,
>> knock wood. It might be that the ones WLM couldn't open or read were
>> related to this problem, but I didn't realize at the time and accidently
>> fixed it and it went away. I have set the compaction count to 100
>> closings
>> and I think it will go higher! I certainly do not look forward to
>> dealing
>> with this any time soon and I leave WLM in the system tray most of the
>> time.
>> I updated to 1606 from 1365 without removing any old stuff or deleting
>> any
>> registry keys [which is how it should work] and it is working way better
>> than the beta release.
>> "Peter" <[email protected]> wrote in message
>> news:e$#[email protected]
>>> Hi again smiles, I imagine it is disappointing and frustrating that
>>> all your messages were 'recovered' again during compaction of your
>>> database. There is no option to prevent a recovery of messages when
>>> required during a database compaction operation. If such recovery
>>> operations continue to happen (or you fear they will), you can try
>>> starting again from scratch with the hope that your new message store is
>>> more stable.
>>> To get yourself a nice new message store, after backing up
>>> everything, close down WLMail, then navigate to your message store
>>> folder. Rename this folder from 'Windows Live Mail' to 'Windows Live
>>> Mail [old]', then restart WLMail. WLMail will automatically recreate a
>>> new message store, which will be free of e-mail accounts etc. and
>>> messages. You can then import your accounts and messages. A folder named
>>> 'Imported Folder' will be created under 'Storage folders', which will
>>> contain your imported messages. However, all the e-mail in your Inbox on
>>> your e-mail account's server may be downloaded the next time you do a
>>> send/receive, so the backup of your Inbox may not be needed.
>>> Cheers,
>>> Peter
>>> (Windows XP Pro SP2)
>>> in
