G
Gabriel Lozano-Morán
Nobody has managed to install Windows Vista Build 5342 in a VMware Virtual
Machine. There is propably a check to see whether this is run in VMware,
using Strings.exe from Sysinternals you will see what I mean
Way to go
Microsoft
Gabriel
"FredBloggs2" <[email protected]> wrote in message
news:%[email protected]
>I am unable to install 5342 under VMware Workstation 5.5. It fails with a
>Stop 0x7E error during the first part of the installation, ie after Windows
>has copied files to the HDD, and it switches to graphics mode, to where (I
>assume) it begins to perform the first bit of hardware detection.
> The install worked fine with build 5308.
> For what its worth, the config is as follows :
> VMWare WS 5.5 runnning on XP Pro Sp2
> AMD XP2500+
> 1GB RAM
> 300GB Maxtor
> Apparently the same thing happens under VMware GSX server..
Microsoft
Gabriel
> AMD XP2500+
> 1GB RAM
> 300GB Maxtor
