Re: Volume control gone from taskbar
T
TheDuck
Open control panel in upper right search block enter 'tray speaker' and it
will give you an option to display it on the tray.
"Barry" <user@newsgroup/> wrote in message
news:ONqUnRAsKHA.6140@newsgroup
> Am not skillful, but would like volume control returned to taskbar.
> Currently have volume, but it is too loud.If you can fix it, tell me how.
> Remember I am NOT skillfull.
> frmsrcurl:
> http://msgroups.net/microsoft.public.windows.vista.hardware_devices/
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hello Melanie,
You might see if this may be able to help you get the Volume icon back in the notification area.
http://www.vistax64.com/tutorials/106787-notification-area-system-icons.html
I'm having the same problem, I think one of the auto updates must have done something. When I go to task bar properties the volume icon is grayed out, you can't click on it to display, so the above fix does not work and probably won't work for Barry either.
frmsrcurl: Volume control gone from taskbar - microsoft.public.windows.vista.hardware_devices | Microsoft Newsgroups
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
R
Rick Rogers
See:
http://www.mydigitallife.info/2009/...ith-disabled-or-grayed-out-check-box-options/
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Melanie" <user@newsgroup/> wrote in message
news:umu4QSBuKHA.6140@newsgroup
> frmsrcurl:
> http://msgroups.net/microsoft.public.windows.vista.hardware_devices/Volume-control-gone-from-taskbar
