RE: WMP 11 slow to add files?
S
sfink
I am running windows media 11 in XP and I have about 11,000 songs on an
external hard drive and it has been adding files to media player library for
over 12 hours and its only up to the letter 'P' not even 2/3 done. I hope
this is not going to be happenning in the final release..
"Shawn Oster" wrote:
> When I try to drag and drop my "Music" folder from my networked folder
> (which has about 2000 albums) it takes a long time for it to parse a single
> album. I stopped it after two minutes and only 6 albums had been added.
> Just checking if it's just me or the current state of WMP.
> I don't want to add it as a "Watched Folder" because I don't need it polling
> in the background, I just want to build my initial library.
> Shawn Oster
A
Andre Da Costa [Extended64]
You should be able to close the dialog and continue to browse and listen to
what has been added to the library so far.
Andre
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
"sfink" <[email protected]> wrote in message
news:[email protected]
> for
>> single
>> polling
>> Shawn Oster
J
jamestony
Can Someone tell me how to add files to my WMP 11 library, when I assign a
folder to watch for media files it does nothing. When I go back to check if
the folder is still there the space to enter the folder is empty. I just
want to know how to add files to my library. Thanks
> Andre
> > for
> >> single
> >> polling
> >> Shawn Oster
