Read-Host issue, won't store to variable when using multiple read-host lines
  • Thread starter bryan.rutkowski@gmail.com
  • Start date
B
I am prompting the user to enter new user information in using Read-
Host. The only problem is, when I run my function and enter the data
in, it doesn't exists, all the variables are null. If I just do each
one, one at a time outside of the function I can get read-host to work
fine. But whenever I try to do more then one at a time it doesn't
work at all. Below is my code. So once I run the function create-
user and try to get the data in any of the variables (ex.
$strLogonName) they are all ways null. Does anyone have any ideas?
function create-user{
# Asks the user to input the Account name they wish to create.
$strLogonName = read-host "Enter the users Logon Name, use ** as a
wildcard where you would want the State Code to go"
# Asks the user to input the Domain Suffix of the user.
$strDomainSuffix = read-host "Enter the users Domain Suffix, ex.
@cars.com"
# Asks the user to input the First Name of the user.
$strFirstName = read-host "Enter the users First Name, use ** as a
# Asks the user to input the Last Name of the user.
$strLastName = read-host "Enter the users Last Name, use ** as a
# Asks the user to input the Description for the user.
$strDescription = read-host "Enter the users Description, use ** as a
# Asks the user to input the Password of the user.
$strPassword = read-host "Enter the users Password, use ** as a
# Asks the user to input the OU Path they wish to create the user in,
do not include the Domain DN.
$strOUPath = read-host "Enter the OU Path. Leave out all domain
specific information, use ## as a wildcard where you would want the
State Code to go"
R
RichS
RE: Read-Host issue, won't store to variable when using multiple read-
How are you returning this information from your function?
I've just tried the function & the variables seem to pick up the input OK
Richard Siddaway
Please note that all scripts are supplied "as is" and with no warranty
Blog: http://richardsiddaway.spaces.live.com/
PowerShell User Group: http://www.get-psuguk.org.uk
> @cars.com"
> State Code to go"
B
Re: Read-Host issue, won't store to variable when using multiple read-
Here is the exact output when I run it.
PS C:\Documents and Settings\bryan.rutkowski> function create-user{
>> $strLogonName = read-host "Enter the users Logon Name, use ** as a wildcard where you would want the State Code to go
>> $strDomainSuffix = read-host "Enter the users Domain Suffix, ex. @cars.com"
>> $strFirstName = read-host "Enter the users First Name, use ** as a wildcard where you would want the State Code to go
>> $strLastName = read-host "Enter the users Last Name, use ** as a wildcard where you would want the State Code to go"
>> $strDescription = read-host "Enter the users Description, use ** as a wildcard where you would want the State Code to
go"
>> $strPassword = read-host "Enter the users Password, use ** as a wildcard where you would want the State Code to go"
>> # Asks the user to input the OU Path they wish to create the user in, do not include the Domain DN.
>> $strOUPath = read-host "Enter the OU Path. Leave out all domain specific information, use ## as a wildcard where you
PS C:\Documents and Settings\bryan.rutkowski> create-user
the State Code to go: ** Logon Name
Enter the users Domain Suffix, ex. @cars.com: @cars.com
the State Code to go: John
the State Code to go: Doe
the State Code to go: John Doe
the State Code to go: 12345
o go: ou=cars
PS C:\Documents and Settings\bryan.rutkowski> $strlogonname
PS C:\Documents and Settings\bryan.rutkowski> $strDomainSuffix
As you can see nothing is set in the variables. Am I doing something
wrong, or calling them the wrong way?
> Richard Siddaway
> Blog:http://richardsiddaway.spaces.live.com/
> PowerShell User Group:http://www.get-psuguk.org.uk
> > @cars.com"
> > State Code to go"
R
RichS
OK I see your problem now. You are creating the variables inside the
function and they work OK and get the values you input. When you get to the
end of the function it in effect closes and those variables and the values
they hold are lost. You need to return the values out of the function.
I'll put an example together & post it in a while
Richard Siddaway
> go"
> o go: ou=cars
> > Richard Siddaway
> > > @cars.com"
> > > State Code to go"
S
Stephen Merkel
You could give your variables global scope (i.e. outside of the script that
creates the function) by addidng 'global:' between the '$' and the name of
the variable.
Like this $global:strLogonName
Merkel-DBA
> @cars.com"
> State Code to go"
R
RichS
Based on your function this is how you could get it to work in the way you
seem to want to. Notice the return statement at the end of the function
@cars.com"
# Asks the user to input the OU Path they wish to create the user in,do not
State Code to go"
return $strLogonName, $strDomainSuffix, $strFirstName, $strLastName,
$strDescription, $strPassword, $strOUPath
$strLogonName = ""
$strDomainSuffix = ""
$strFirstName = ""
$strLastName = ""
$strDescription = ""
$strPassword = ""
$strOUPath = ""
create-user
$strLogonName = ""
$strDomainSuffix
$strFirstName
$strLastName
$strDescription
$strPassword
$strOUPath
Richard Siddaway
> go"
> o go: ou=cars
> > Richard Siddaway
> > > @cars.com"
> > > State Code to go"
B
Richard when I tried your method I was able to get the data output to
the screen right after the function completes, but the variables still
were not kept. They were blank like before.
I tried using Stephen's method of making them global. That worked.
What I am trying to do is get all this user information then use it to
create a user in every domain in our forest. So as soon as the user
inputs the data the rest of my script gets all the domain information
the proceeds to create a user in each domain.
> @cars.com"
> State Code to go"
> $strLogonName = ""
> $strFirstName = ""
> $strLastName = ""
> $strPassword = ""
> $strOUPath = ""
> create-user
> $strLogonName = ""
> $strDomainSuffix
> $strFirstName
> $strLastName
> $strDescription
> $strPassword
> $strOUPath
> Richard Siddaway
> > go"
> > o go: ou=cars
> > > Richard Siddaway
> > > > @cars.com"
> > > > State Code to go"
R
RichS
#8
If you put the rest of your code after the function it should work but if
you've got it work thats good
Richard Siddaway
> > @cars.com"
> > State Code to go"
> > $strLogonName = ""
> > $strFirstName = ""
> > $strLastName = ""
> > $strPassword = ""
> > $strOUPath = ""
> > create-user
> > $strLogonName = ""
> > $strDomainSuffix
> > $strFirstName
> > $strLastName
> > $strDescription
> > $strPassword
> > $strOUPath
> > Richard Siddaway
> > > go"
> > > o go: ou=cars
> > > > Richard Siddaway
> > > > > @cars.com"
> > > > > State Code to go"
