'read only' folder cannot be unlocked
A
A.Translator
My email client writes spelling corrections to a .tlx file in a folder that
Vista has marked 'read only' . I have tried to uncheck the 'read only',
authorized everybody to do everything (I am desperate!), even did it all again
with UAC off, but the folder remains 'read only' . I can manually change and
save the .tlx file, but that is not what I want to do. I am logged in as
administrator and using Vista Home Premium.
Can someone tell me how to unlock the folder?
Thank you.
Groet,
Adriana
[ gooi de vuilnis weg als je me wilt mailen ]
www.spinsister.nl
M
Michael Walraven
Folders are not 'read only', notice that the box is a filled in square, not
'checked'. You can fiddle with that box all you want there will be no
change. Files may be 'read only' but the attribute does not apply to
folders.
Michael
Vista Home premium
"A.Translator" <transVUILlatoria@xxxxxx> wrote in message
news:mn.239f7d7c35c80248.33167@xxxxxx
> that Vista has marked 'read only' . I have tried to uncheck the 'read
> only', authorized everybody to do everything (I am desperate!), even did
> it all again with UAC off, but the folder remains 'read only' . I can
> manually change and save the .tlx file, but that is not what I want to do.
> I am logged in as administrator and using Vista Home Premium.
> Thank you.
> Groet,
> Adriana
> www.spinsister.nl
A
A.Translator
Michael Walraven schreef op 4-12-2007
> 'checked'. You can fiddle with that box all you want there will be no change.
> Files may be 'read only' but the attribute does not apply to folders.
I stand corrected. But how do I get the corrections in my spelling checker to
be accepted?
Groet,
Adriana
www.spinsister.nl
Dzomlija
Resistance is Futile
2,213
Location
South Africa
be accepted?
Where are the ".tlx" files being saved? If they are being saved to any sub folder of "C:\Program Files" or "C:\Program Files (x86)", then the security protocols of Vista do not allow applications to write anything to those folders, other than an installer type application.
If possible, change the settings of your mail program to have it save these files to a different location, or go to the application manufacturers website for an update where this problem may have been addressed.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
A
A.Translator
dzomlija schreef op 4-12-2007
That is the answer. Thank you. They are saved here: C:\Program Files\The
Bat!\Speller - where The Bat! is my email client.
I will contact the maker of the software.
Groet,
Adriana
www.spinsister.nl
Dzomlija
2,213
Location
South Africa
That is the answer. Thank you. They are saved here: C:\Program Files\The Bat!\Speller - where The Bat! is my email client. I will contact the maker of the software.
I took the liberty of checking for you (RITLabs. The Bat! Email Client). The newest version of "The Bat!" is dated 19 October 2007. Perhaps the problem you mentioned will be fixed with that release?
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
M
Michael Walraven
Need more information on what program you are using that is doing the
spelling checking, and the location that is holding the user dictionary.
for instance in my system
Word 2007: C:\users\walraven\appdata\roaming\microsoft\uproof\custom.dic
Windows Live Mail: c:\users\walraven\appdata\local\microsoft\windows live
mail\proof\lang0409.lex
these locations are available to my as the owner of those locations.
Michael
Vista Home premium
news:mn.23db7d7c03287d72.33167@xxxxxx
>> not 'checked'. You can fiddle with that box all you want there will be no
>> folders.
> to be accepted?
> Groet,
> Adriana
> www.spinsister.nl
A
A.Translator
#8
> I took the liberty of checking for you ('RITLabs. The Bat! Email
> Client' (http://www.ritlabs.com/en/products/thebat/)). The newest
Thanks for that. I have the latest version of The Bat! which is supposed to
`work with Vista`. Most things go smootly. This speller problem is the first
thing I ran into on Vista.
Groet,
Adriana
www.spinsister.nl
A
A.Translator
#9
You must have missed the info I gave earlier±
email client.
Groet,
Adriana
www.spinsister.nl
T
Tim Slattery
#10
The folder is not read-only. That attribute has no meaning for
folders. What you are seeing is a 3-state box in its third state:
neither checked nor non-checked.
The control exists on the folder's property page as a shortcut. By
checking it and clicking "OK", you can set the read-only property for
ALL files in the folder. By clearing the box and clicking "OK" you
clear the attribute for ALL files in the folder.
To find out whether the file is read-only, right-click it and check
its properties.
Tim Slattery
MS MVP(Shell/User)
Slattery_T@xxxxxx
http://members.cox.net/slatteryt
M
Michael Walraven
#11
Yup, messages passed in the night.....
If you go to c:\Program Files\The Bat!\
and to c:\Program Files\The Bat!\Speller\
do you see in the task bar a new button 'Compatibility Files' ?, if so that
Vista is implementing a feature that 'takes care' of the problem of writing
into the 'program files' area.
When Vista sees a program try to write into that area it instead writes the
files into a compatibility area. Usually a location such as:
C:\Users\yourname\AppData\Local\VirtualStore\Program Files\name of your
program\..\..
Depending on how the program was written this allows operations to seem to
work the same as before, however notice that these 'Virtual' files are now
on a per account basis rather than a global basis.
If you click on the 'Compatibility Files' button you should then see the
actual files the program is accessing/changing.
Michael
news:mn.24337d7c060e261b.33167@xxxxxx
> is my email client.
> Groet,
> Adriana
> www.spinsister.nl
A
A.Translator
#12
Tim Slattery schreef op 4-12-2007
That is what is not working, and I understand now, is not supposed to work.
Thanks, though.
Groet,
Adriana
www.spinsister.nl
A
A.Translator
#13
> work the same as before, however notice that these 'Virtual' files are now on
thank you too, Michael.
I don't want to mess up anything, had no idea it would be so complicated, so I
guess I'll live without the spelling check till the software manufacturer has
found a solution.
Groet,
Adriana
www.spinsister.nl
Dzomlija
2,213
Location
South Africa
#14
found a solution.
Groet,
Adriana
Spinsister
Perhaps contacting their technical support, and relaying this issue to them alert them to the problem. At the very least, they will have one more person that has complained about this (there's bound to have been others). There more people complain about a particular problem, the harder they'll work at solving it....
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
