Read-only on USB
R
Reilwin
The problem:
I have a usb stick (Sandisk U3 Cruzer mini) on which I've saved several
files in a variety of folders. Now, I want to delete some of those files and
folders, but am unable to do so.
Attempting to disable read-only on the folders is useless, and research on
the internet found that having folders set as "read-only" is expected
behaviour and doesn't prevent them from being manipulated.
However, I am unable to deleted any folder (trying to do so results in no
change). Trying to delete the files inside the folders (which are NOT set as
"read-only") has the file disappear from the explorer window, but re-appears
when the window is refreshed.
Other solutions on the web involved changing the user permissions via Disk
X: -> Properties ->Security tab. However, as a removable drive, there is no
security tab available.
Would anybody happen to know how I could delete those files?
Additional System info:
I use Vista Home Premium
Previously accessed those files from computers using Windows XP and Gentoo
Linux.
A
Augustus
"Reilwin" <Reilwin@xxxxxx> wrote in message
news:A8817E91-714A-4D84-A4A2-9B4AAE4A2B85@xxxxxx
> The problem:
> and
Tried taking ownership of the files via the Command Prompt running as
Administrator?
takeown /f filepath should allow you to modify or delete.
D
Darrell Gorter[MSFT]
Hello,
After taking ownership, you still need to acquire permissions.
From the same elevated CMD prompt you need to run something like this.
Icacls.exe filename /grant username:(F)
Thanks,
This posting is provided "AS IS" with no warranties, and confers no rights
|> From: "Augustus" <no_one@xxxxxx>
|> Newsgroups: microsoft.public.windows.vista.general
|> References: <A8817E91-714A-4D84-A4A2-9B4AAE4A2B85@xxxxxx>
|> Subject: Re: Read-only on USB
|> Lines: 18
|> X-Priority: 3
|> X-MSMail-Priority: Normal
|> X-Newsreader: Microsoft Outlook Express 6.00.2900.3138
|> X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.3198
|> X-RFC2646: Format=Flowed; Original
|> Message-ID: <as7Zi.15477$h57.8900@xxxxxx>
|> Date: Sat, 10 Nov 2007 01:04:06 GMT
|> NNTP-Posting-Host: 199.126.147.8
|> X-Trace: edtnps89 1194656646 199.126.147.8 (Fri, 09 Nov 2007 18:04:06
MST)
|> NNTP-Posting-Date: Fri, 09 Nov 2007 18:04:06 MST
|> Path:
TK2MSFTNGHUB02.phx.gbl!TK2MSFTNGP01.phx.gbl!TK2MSFTFEEDS02.phx.gbl!newsfeed0
0.sul.t-online.de!t-online.de!news.glorb.com!newsfeed2.telusplanet.net!newsf
eed.telus.net!edtnps89.POSTED!53ab2750!not-for-mail
|> Xref: TK2MSFTNGHUB02.phx.gbl
microsoft.public.windows.vista.general:202532
|> X-Tomcat-NG: microsoft.public.windows.vista.general
|> > The problem:
files
|> > and
research on
|> Administrator?
