read strings to variable
J
James
I have a text file like this:
1234 45566, 78923 10/02, 10/03, 10/04
6543 46765, 35643 23/03
I want the script to look at each line and read the first string to a
variable(e.g. 1234), then read all strings after and including the
fourth string to another variable (eg. 10/02 to variable, 10/03 to
another variable etc) and then write those variables to a line in
another text file. It would do this for each line in the text file. The
fourth string and after dates and I would like to write it as 2009/10/02
for example.
Basically I want to grab specific text from each line of the text file
and add them to commands. Can anyone help?
Thanks,
James
P
Pegasus [MVP]
"James" <jwanders@xxxxxx> wrote in message
news:Tznom.137737$cf6.136849@xxxxxx
> variable(e.g. 1234), then read all strings after and including the fourth
> string to another variable (eg. 10/02 to variable, 10/03 to another
> variable etc) and then write those variables to a line in another text
> file. It would do this for each line in the text file. The fourth string
> and after dates and I would like to write it as 2009/10/02 for example.
> Basically I want to grab specific text from each line of the text file and
> Thanks,
> James
You need to read each line with the ReadLine method of the File System
Object. You then split each line into its components like so:
aComponents = split(sLine)
This will allow you to access each component separately:
wscript.echo "String 1 = " & aComponents(0)
wscript.echo "String 2 = " & aComponents(1)
etc.
All of the above is covered extensively, with examples, in the help file
script56.chm which you can download from the Microsoft site.
