read/write/create 'dbf' file
K
kazik
What driver should I use for support 'dbf' files? I was trying
Microsoft.Jet.OLEDB.4.0 but it doesn't support 64 bit computer. I need
to have support for my application on Windows Vista (32/64 bit), Windows
XP (32/64 bit). Is there any one driver for all this requirements? or I
need one driver for Vista and another on XP?
regards
daniel
P
PvdG42
"kazik" <[email protected]> wrote in message
news:[email protected]
> Hi,
> Microsoft.Jet.OLEDB.4.0 but it doesn't support 64 bit computer. I need to
> have support for my application on Windows Vista (32/64 bit), Windows XP
> (32/64 bit). Is there any one driver for all this requirements? or I need
> regards
> daniel
You probably won't find the "driver" to solve your problem. Searching MSDN,
I found a reference to this workaround.
http://www.sharewareupdate.com/preview/dbf_to_sql/
DBF to SQL 2.01
DBF to SQL Converter allows you to convert your dbf files to SQL script. You
can apply this script on any SQL server, so you can easily transfer your
data to a new system. There are several different SQL servers, but this
program allows you to customize the output file. Currently it support MS
SQL, etc. The program supports dBase III, dBase IV, FoxPro, VFP and dBase
Level 7 formats. The program supports command line interface. Besides, the
Site license includes a DLL which you can use from your own application.
Platforms: Windows Vista Ultimate, Windows Vista Ultimate x64
