Reading registry from vmdk files
smkris
3
Loading the software registry hive trouble
Greetings
I was wondering if there is a way to read the registry from a virtual disk.
What I want to achieve is a way to check what software is installed on vmware images that is powered off (licence control). I'm using VMware DiskMount Utility to mount the virtual disks to a local drive path, but just reading the software registry file, located here C:\Windows\System32\config, results in a lot of garbled text (as expected).
In other words. Is there a way to load a registry hive the same way in powershell as its done in regedit? I found a way to search the registry of a remote server but that would require us to start all the dormant vmware images to check what software is installed.
Any help is appreciated
Cheers,
Magnus
smkris
3
I figured out part of the problem
By using reg load. But I get some error message when I try to do this:
PS Z:\windows\System32\config> reg load hklm\tempSoftware "Z:\windows\System32\config\software"
ERROR: The system has attempted to load or restore a file into the registry, but the specified file is not in a registry file format.
If I try to load system there is no problem. I tried to do it manually in regedit and got the error "error while loading hive"
Could this be because I try to load an xp hive on a Vista machine? If that is the case is there a workaround for that problem?
