Real player just popping up randomly
linsjean
32
Location
Oregon
I have no idea why Real Player is popping up randomly. Not when I boot up from a shutdown or restart, just doing usual business on my laptop. I imagine you want me to take note when this happens, but it is really strange behavior. I thought my default player was Windows Media Player, but I could have changed that because I was having problems gettng my iPod to sync, bla bla bla.
Do you know what could cause this strange behavior?
Thanks!
Linda
    HP/Compaq Presario CQ60 Notebook PC
    Intel(R) Pentium(R) Dual CPU T3400 2.17 GHz
    2 gigs
    1366 x 768
MilesAhead
Eclectician
2,442
Try just installing another player. That should reset all the file type associations for media files. Then when you run wmp it will probably ask you if you want to change them back. Click that you do. May work, may not but usually with stuff like that you have to switch apps, then switch back, like when you change default browser. Never works exactly how you expect. You have to switch away from what you want first, so you can switch back. :)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
linsjean
32
Location
Oregon
Miles,
I appreciate your quick reply, but I'm still confused :( You know how sometimes words get misconstrued when typing. I try my best, but I'm still not very good at it. I will try to clarify.
I want Real Player to be my default player (because that is where all my playlists are for my iPod), but I don't know why it launches on its own without me asking it to. It just launches without any rhyme or reason. Any ideas on this? Thanks again.
    2 gigs
    1366 x 768
MilesAhead
Eclectician
2,442
I understand. Usually when a program comes up for no reason it's because it's associated with a file type that it shouldn't be. I would try my suggestion because even if it doesn't work, it shouldn't hurt anything. If it doesn't work then I'd try a forum that's more specific to Real Player. If it's happening to you then it's probably happening to other RP users, so an RP forum would concentrate those questions and solutions or work-arounds. May be a bug specifig to RP. I use VLC so RP I don't know much about.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
MilesAhead
Eclectician
2,442
The other thing that works sometimes is uninstall the program, and install it again.
I should have thought of that earlier. :)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
dk70
Vista Pro
213
I dont know Real Player either but you can be sure default settings are made so Real Player gets highlighted, in your face. Check this Stop Real Player Downloader Pop Up • mozillaZine Forums and after that go through all settings in Real Player. Itunes/Quicktime, WMP, Real Players, others will all fight for your attention.
Be sure you have latest version btw. Hopefully needed changes are possible to make in normal preferences window and no "hacking" is required, like turning off services and such.
    AMD X2 6000
    Gigabyte GA-MA790FX-DS5
    Corsair 4x1gb 6400C4
    XFX 8800GTS XT 320mb, Generic Nvidia 6200 PCI 128mb
    Onboard Realtek ALC889A
    24" Samsung 245b, 20" Dell 2007WFP, 19" Samsung 193P
    WD Raptor 74gb, Maxtor 300gb, WD Caviar 16SE 500gb
    Corsair 520W
    Cooler Master Centurion 532
    Logitech MX1100R
    Logitech G15
    20mb down, 1mb up
