Recommended Fax Boards For Receiving Faxes on HP ProLiant ML350 G4p?
S
SuperFlyBoy
Anyone have any recommendations for affordable fax (PCI?) boards to put
into our server to use with SBS2003?
TIA!
S
SuperFlyBoy
Re: Conficker Attacked Server - Now Domain Down - SBCore Service Acting Up
Well, since I cannot edit my first post, adding this:
5. Tried to restart the SBCore service, but when I do, gives:
"Could not start the SBCore service on Local Computer
Error 5: Access is Denied"
6. Single NIC - no ISA.
A
Andrew Rinaldi
Re: Recommended Fax Boards For Receiving Faxes on HP ProLiant ML350G4p?
I'm not sure of your definition of 'affordable'... Mainpine make high
performance Fax boards and software that enhances Microsoft Fax. The
boards are PCI Express and will fit into either of the ML350 G4 PCI
Express slots.
Andrew Rinaldi
Mainpine Developer Support
R
Russ SBITS.Biz [SBS-MVP]
On SBS2003 I've had good luck with Old Serial USR Fax modems
(the older the better)
However make sure that you are connecting with a "ANALOG" Line not digital.
Because of issues of SBS2008 and faxes I've been trying to move them to and
E Fax Solution
or even using the copier with fax and email ability.
I wish I could say I've had good luck with one card 100% but I haven't
even the Expensive ones :(
Russ
Russell Grover - SBITS.Biz [SBS-MVP]
MCP, MCPS, MCNPS, SBSC
Remote Small Business Server/Computer Support - www.SBITS.Biz
BPOS - Microsoft Online Services - www.Microsoft-Online-Services.com
S
SuperFlyBoy
I think I started another thread for fax boards...but thanks for the
feedback guys!
I really would like some guidance on how to extract the mails from this
old install and put them in the new one.
R
You using techarena is confusing you ;)
R
And do you mean EXMERGE?
S
SuperFlyBoy
SuperFlyBoy;4962681 Wrote:
> I have tried to use the EXMERGE utility to try to extract the mailboxes
> and have prepared another (fresh) install of SBS2003, Exchange2003 SP2
> to run on the same machine (on another HD), but since the mailboxes are
> larger than 2 GB, the full information cannot be extracted.
'Russ SBITS.Biz [SBS-MVP Wrote:
> ;4963439']And do you mean EXMERGE?Yes, as I posted earlier - quoted above.
> ;4963438']You using techarena is confusing you ;)Didn't know that the "Westerners" frequenting this Indian-domained site
were as "whacked" as the systems that prevail here in India! :p
A
Andrew Rinaldi
Have you tried an IQ Express and the IQFSP software?
Andrew Rinaldi
USA +1 866 363 6680 | UK +44 1225 637 105
[email protected] | www.mainpine.com
