Recovery problems, 32bit
Shadoweb
1
My laptop took a mean spill and lost it's LCD screen. I repaired the screen and it began to give me errors. At the moment it's missing a "system32\config\system". I found my Vista recovery disk, it loads the files and shows me a Microsoft loading bar. It passes the bar and stops at a black screen with the arrow cursor on it. Is this supposed to happen? How long do it take for the disk to show me the recovery options?
M
Malke
> options?
More than just your LCD screen was damaged. Whether it is the motherboard,
the hard drive, the optical drive or a combination of components is
impossible to say without physically examining the laptop. Either contact
the laptop mftr.'s tech support for repair/replacement or take it to a
competent local computer tech. This will not be someone from a
BigComputerStore/GeekSquad type of place.
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
http://www.elephantboycomputers.com/#FAQ
