Recycle Bin Won't Show When Full
C
coliver
I previously posted about my recycle bin not going back and forth when it's
empty and showing when it's full. It just shows empty all the time. Thanks
for the responses, but none of those worked. I went to Personalization,
clicked Recycle Bin, even clicked the "full" icon and clicked Restore
Default, but it still doesn't work. I just want my regular recycle bin
back!!!! HELP!!!
M
Michael Walraven
Are you really sure that it doesn't change? On my Vista Home Premium the
difference is very small visually. To see mine change I have to stare at it
while I empty it, otherwise I cannot easily see the difference. (It is much
more obvious in XP). You might try changing the Icons temporarily to other
more obvious icons to see if it works. Then change them back, sometimes
changing things and changing them back clears out stuff - its magic :)
Michael
"coliver" <coliver@xxxxxx> wrote in message
news:67D5E628-FC8F-4B83-8632-A8752948EBBC@xxxxxx
> Thanks
> back!!!! HELP!!!
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
back!!!! HELP!!!
Hi Coliver,
Try the solution here to see if will fix your problem for you.
http://www.vistax64.com/tutorials/66294-recycle-bin.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
