Redirected "My Documents" gives folder not availble error when trying to say
  • Thread starter James L. Williams
  • Start date
J
James L. Williams
Hello,
I have Vista business on my new computer laptops. They are connected to a
Windows 2003 Domain. Each one of the "My Documents" for each user is
redirected to the 2003 server. Each user can access and view the documents
in the redirected folder, however every time they try to create a new
document or save a change to an existing one, a windows comes up saying the
the folder does not exist. I suspect the problem is because their is no
local account for the user. In Windows XP, I never had to do this. Also,
the OffLine is not working either, it says it is enabled, but not activated,
and to restart the computer, but this doesn't work.
Any Ideas? I have three new computers and it does the same on all of them.
Regards,
James
