Reflection with Generic Collection types
  • Thread starter Fernando Arámburu
  • Start date
F
Fernando Arámburu
hi everybody,
I´m working on a very strange dotnet Reflection component and i´m having
some troubles with reflection on generic types. To talk more concretely I
will gvie you some examples of what i´m looking at.
The method where I´m having some troubles needs to do get the generic
collection type from a generic collection variable. Examples (Please forget
about namespaces, í´m not writing them just to be more clear)
I have My Method
should return
List<int> List< >
type instance
Dictionary<string, object> Dictionary<> type
instance
By now I know how to get the parameter types (like int in the first
example and string and object in the second one) and how to get something
like List'1<int> or Dictionary'2<string, object> and I know I can parse the
type name as a string and then everything is fixed but I think there is some
whay to get what i´m looking at by using Reflection library. Can someone
give me a hand?
Thanks in advance.
Fernando
C
Cor Ligthert[MVP]
Fernando,
Are you sure you cannot simple set Option Strict to Off to get the same
results without reflection?
Cor
"Fernando Arámburu" <fernando@xxxxxx-group.com> wrote in message
news:u1J7ZKghJHA.1184@xxxxxx
> hi everybody,
> having
> forget
> I have My Method
> should return
> List<int> List< >
> type instance
> instance
> the
> some
> give me a hand?
> Thanks in advance.
> Fernando
C
Cor Ligthert[MVP]
Sorry,
I thought that I was answering from the VB newsgroup.
Cor
> hi everybody,
> having
> forget
> I have My Method
> should return
> List<int> List< >
> type instance
> instance
> the
> some
> give me a hand?
> Thanks in advance.
> Fernando
F
Fernando Arámburu
No problem Cor. Thanks anyway.
Fernando
"Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> escribió en el mensaje
news:ODslEqjhJHA.5732@xxxxxx
> Sorry,
> Cor
>> hi everybody,
>> having
>> forget
>> I have My
>> Method
>> should return
>> List<int> List< >
>> type instance
>> instance
>> the
>> some
>> give me a hand?
>> Thanks in advance.
>> Fernando
