Regsvr32 error 0x80004005
C
chris
Whilst running regsvr32 for an ocx component I get an error 'the module
'blah.ocx' was loaded but the call to DllRegisterServer failed with error
code 0x80004005.
Any ideas anyone ?
R
Ramesh, MS-MVP
Chris,
0x80004005 denotes "Access is denied" error. See if running the Regsvr32 command-line from an elevated Command Prompt helps.
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows XP Shell/User]
R
Ronnie Vernon MVP
Josef
You simply right click the Command Prompt shoercut and select Run As
Administrator from the pop-up menu.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
P
Paul-B
Open a command box as administrator... right click the icon and select
the "Run as Administrator" option.
Paul-B
O
Overstressed admin
no such luck
The error message was the same. I tried running as an admin, logged on as an admin, no such luck. First time I have seen this. Trying to setup muvpn on vista.
regsvr32.exe C:\Windows\System32\irebase.dll returns error "irebase was loaded but the call to DllRegisterServer failed with the error0x80004005
R
Ramesh, MS-MVP
Re: no such luck
May be a registry permissions issue. Use Regmon or Process Monitor to track.
Regards,
Windows® XP Troubleshooting http://www.winhelponline.com
<Overstressed admin> wrote in message news:[email protected]
Larkspur
I am having the same problem as mentioned here. I do not have command prompt icon. ? I tried to run the command (regsvr32 path\vbscript.dll) from the 'DOS' command prompt but am unsuccessful. How can I run this as an administrator?
R
Ramesh, MS-MVP
To open an elevated Command Prompt, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator.
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
brianm
I had the same problem. Running the command prompt as administrator worked for me as well. I was surprised though, because my user is part of the adminstrators group. Does anyone know what the difference is between running as administrator and being part of the administrators group? I thought they had the same level of priviledges.
Brian
R
Ramesh, MS-MVP
Hi Brian,
This is a major change in Windows Vista. Although the user may be part of the Administrators group, they run in standard user mode. When a system-wide operation is performed, the elevation dialog is shown. In case of legacy applications (that don't have the requireAdministrator flag set in the manifest), the user need to right-click on the program and choose "Run as Administrator".
See also:
User Account Control Overview:
http://technet.microsoft.com/en-us/windowsvista/aa906021.aspx
Regards,
vimales
Hi Ramesh,
I did as you suggested, typed in Run as admin and it did say vbscript.dll succeeded.
But when I'm in systems32, trying to open a .dll file with Microsoft(C) Registry Server, the same error popped out.
I am lost, pls help....
stressed,
Vimales
A
Aldridge
This problem may occur if a file that the Windows Product Activation
(WPA) requires is damaged or missing. This behavior occurs if one or
both of the following conditions are true:
- A third-party backup utility or an antivirus program interferes
with the installation of Windows XP.
- A file that WPA requires is manually modified
you can try this
http://forums.techarena.in/operating-systems/1127102.htm
Aldridge
Dileep
While running regsvr32 for registering a vb6 application dll i got an error message "DllRegisterServer failed with error code 0x80004005."
Any ideas anyone ?
