Reinstall/Fix Internet Explorer on Vista
D
[email protected]lemail.com
Hi, I'm having a few annoying problems with IE& on Vista, and I
wondered if there was a way to reinstall the IE7 components.
I'm running Windows Vista Home Premium edition (fully patched) and I
have a number of issues that have existed possibly since the machine
was built - i.e. I'm not sure it ever worked!
The problems include:
1. The Search tool bar doe not work, I can type in it - but
pressing enter, or the search icon does nothing
2. The drop-down list of "back history" does not appear ... the
back button functions fine, but the drop down does not work
3. Most annoying of all - downloads, or new windows that are
invoked via script do not work, there are two different versions of
this fault:
a) the window will open and do nothing, but you can "stop"
the page and press refresh -- and then it works fine.
b) if the window is a pop-up the URL is not populated, and
there is no way to stop / refresh ... in this case I have found no
work around (other than firefox).
The problem also exists in the "no add-ons" version - but I'm not a
fan of add-ons anyway, so I only run Google toolbar.
Can anyone help?
Darren
T
Tiberius
get this: in order to repair ie7 on vista you have to repair the whole OS.
Smart thinking from MS right?
try the shortcut that launches IE7 with no plug-ins (add-ons)
that you will find in the start menu as below:
Start> All programs> accessories> system tools>
Internet Explorer (No Add-ons)
see if that lets Ie7 work...
I would suggest you also downloading some antispyware like spybot search and
destroy
and adaware (search for them both on www.download.com they are free)
as well as doing a scan with windows defender.
tell me if any of this helps
T
Tiberius
I use avantbrowser from www.avantbrowser.com and firefox
avant is a shell for the ie engine... and has a far more usable interface
than the stupid one they
gave IE7 that is a peice of TRASH!!!!
Hi Tiberius, thanks for your reply, as above the no-addons version
does not fix the issue, and spyware scans etc are clean. I think this
maybe a total rebuild required. which would be a pain, especially
since I don't know if this will fix the issue. I guess I can use the
process to identify what "causes" the issue.
Thanks again!
Darren
Well, I did it ... started from scratch and discovered that the root
cause of the issue was an install for Microsoft Office OneNote 2003 -
without this installed it works fine, installing it causes the issue.
System Restore corrects it.
I hope this is of use to someone else :)
J
jasestar1
I installed Firefox and laerturne dof the machin and when I logged back
on I go a add-on meeage for firefox I chicked yes - stupidly - and then
I got the couldn't connect message, which has alos now gone to Internet
Explorer. Anyone got any ideas to fix?
