reinstall vista?
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    500gb Seagate SATA II
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
    AVerMedia 1500MCE TV Tuner
johngalt
Antidisestablishmentarian
On the second one - if you already have Vista for that machine, and replace the processor, most likely you will *not* have to reinstall - but you may have to re-activate.
If your Vista install is from a completely different computer, yes, you'll have to start from scratch.
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Calssified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    2 * Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA II
    Seagate Barracuda 7200.12 ST1500DL001 1.5 TB SATA II
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    180 Mbit down / 15 Mbit up
    3 VMs built off IP 14971:
    UUP disabled / single VHD | UUP disabled / dual VHDs with moved \User Tree | UUP enabled / single VHD
Dwarf
The Contemplator
Hi thepizzaman,
According to the Acer website, this type of processor is supported - see image for detailed specification of the Aspire M1200 series.
As regards whether or not you need to reinstall Vista, the best advice that I can give you (and others contemplating hardware upgrades) is this: When upgrading major hardware components, ALWAYS be prepared for the need to reinstall Vista. On some occasions, this will not be necessary, but if you back up your data and prepare for this eventuality then you will be able to get your system up and running much more easily.
I have, in the past and on my other system, upgraded a number of components, including the processor, and have had NO need to reinstall Vista. However, both processors were single core with the same architecture but a different speed. Here you are proposing to replace a dual-core processor with a quad-core one. This difference in architecture may require you to reinstall Vista.
Of course, you may find that you can pop in the new processor and continue where you left off without any problems, but, as stated above, it is wise to prepare yourself just in case.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
thanks! :) looks like i'm gonna get a quad soon :)
    1680 X 1050
    6 Mbs Down 1 Mbs Up
